Toymods » Tech & Conversions » 1G-GTE Mid Sump Models ?
ra23celica
1G-GTE Mid Sump Models ? Fri, 14 May 2004 03:20 Go to next message
Correction:
Sorry to say but a friend of mine is doing a non-Toyota conversion, fitting a 1G-GTE to a euro car Rolling Eyes . He needs a mid-sump version. Just to narrow the field when we go looking at half-cuts this weekend, what model Toyota's have the 1G-GTE with a mid-sump please?
Many thanks,
Mitch.
[Updated on: Fri, 14 May 2004 03:23]
Darkstar
Ebbw Vale, Qld
Re: 1G-GTE Mid Sump Models ? Fri, 14 May 2004 03:47 Go to previous messageGo to next message
I'm not sure, really..
When i put a 1ggte in my cressida, i needed a mid-sump for it to fit, but i couldn't find one. I had to cut and weld, yes it is possible. Just be careful of the oil pick-up, but trust me, it is possible.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1G-GTE Mid Sump Models ? Fri, 14 May 2004 04:22 Go to previous messageGo to next message
Out of all the 1G-GTEs, I've only ever seen Gen 1 (water-to-air) versions have the front sump. If you get a Gen 3, you should be sweet.
FWIW, 1G-GEs and (I think some) 1G-GZEs have front sumps.
ra23celica
Re: 1G-GTE Mid Sump Models ? Fri, 14 May 2004 05:23 Go to previous messageGo to next message
Thanks Darkstar and Nark,
This helps the search for sure. Any idea on which GZE's had front sumps? I might have to look at sump and oil pick-up swaps if we can't find the right combination.
Mitch.
HyDrA
Adelaide, SA
Re: 1G-GTE Mid Sump Models ? Fri, 14 May 2004 05:33 Go to previous messageGo to next message
GA70 Supra's had mid sumps... I have a mid sump, baffle and pickup here... make an offer if you'd like it Smile
Nark
Cabramatta, NSW
Re: 1G-GTE Mid Sump Models ? Fri, 14 May 2004 06:44 Go to previous messageGo to next message
Mitch, if you can get away with using the front sump at all, then do so!
It's a far superiour design.
ra23celica
Re: 1G-GTE Mid Sump Models ? Fri, 14 May 2004 07:34 Go to previous messageGo to next message
Nark,
Thanks for the heads up mate, that is what I will aim for.
Mitch.
Bugman
Re: 1G-GTE Mid Sump Models ? Sat, 15 May 2004 00:34 Go to previous messageGo to next message
nark that really has to be arguable.
surely toyota would not go backwards in there design.
There are also plenty of big HP 1Gs still running fine on the rear sump..
Mind you I have a front sump now.
Nark
Cabramatta, NSW
Re: 1G-GTE Mid Sump Models ? Sat, 15 May 2004 00:44 Go to previous messageGo to next message
I'd suggest this scenario:
Toyota created an engine. Then wanted to put it into the xA70 Supra and found that the sump wouldn't fit.
So they put a bit of money and a bit of research into creating a mid-rear sump.
I don't know. I've seen both types and the front sump has much better internal baffling.
gold28
Madrid - Spain
Re: 1G-GTE Mid Sump Models ? Tue, 18 May 2004 04:59 Go to previous messageGo to next message
Gen3 soarers are front sump.
AFAIK all supra 1G's were mid sump, definitly the Gen3's
The front winged sump has a better windage tray than the mid sump setup and larger sump volume. You have to remember that the 1G was the economy option for the cars it was manufactured in. I don't think toyota really expected to need a high performance sump in a 1G supra.
amon
Darwin
Re: 1G-GTE Mid Sump Models ? Tue, 18 May 2004 08:58 Go to previous message
I just bought a GZ20 halfcut gen 3 it has a mid sump if thats any help
Guy
Previous Topic:AE86 wheels
Next Topic:engine condition
Current Time: Sat Oct 31 21:07:37 UTC 2026
Total time taken to generate the page: 0.0048139095306396 seconds
