Toymods » Tech & Conversions » 1ggte fuel pump
Darkstar
Ebbw Vale, Qld
1ggte fuel pump Fri, 14 May 2004 03:40 Go to next message
Does the standard fuel pump in a cressi with 7mge have enough flow rate for a 1G-GTE? I guess the obvious solution would be to get the pump from a GA70, but will my current pump (7mge) be adequate?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1ggte fuel pump Fri, 14 May 2004 04:20 Go to previous messageGo to next message
I'm using a stock RA65 tank and it flows enough for my engine which puts out 124kW. Stock Gen 3 (ie: 11psi).
Dylo
Re: 1ggte fuel pump Fri, 14 May 2004 05:18 Go to previous messageGo to next message
I can tell you that a 7M-GE pump wont flow enough fuel for a 1GGTE. I have tried this, and hence why i am now selling a 7M-GE fuel pump Wink
It cant flow enough fuel at full boost, after about 6000rpm
Dabbid
Yowie Bay, Sydney
Re: 1ggte fuel pump Fri, 14 May 2004 08:06 Go to previous messageGo to next message
must just be your particular pump
i've used an mx83 pump with 7mgte and still hard 2lt/min return to the tank and full pressure...
and i doubt it uses less fuel than a 1g
Dylo
Re: 1ggte fuel pump Sat, 15 May 2004 01:22 Go to previous messageGo to next message
Yeah i was beginning to wonder if the dickhead sold me a 5M pump or something that could be why it was so lame!
Siktoy ra23
Plumpton/sydney
Re: 1ggte fuel pump Sat, 15 May 2004 11:31 Go to previous messageGo to next message
don't bother playing games and get a vl turbo fuel pump and you will have no problems
Bugman
Re: 1ggte fuel pump Sat, 15 May 2004 12:33 Go to previous messageGo to next message
I got one for sale, saw 5,000 ks brand new from the box.
CrAiGzEE
south of the big smoke
Re: 1ggte fuel pump Sat, 15 May 2004 14:40 Go to previous messageGo to next message
ahaha bugman what happened to ya old pump Razz tell them what not to do !!
ra23celica
Re: 1ggte fuel pump Sun, 16 May 2004 11:43 Go to previous messageGo to next message
According to the Goss fuel pump cattledog a 7M GE Cressida pump will do something like 208 l/hr max flow and 111 l/hr at 36.2 psi, so more than enough for your 1G-GTE. I suspect your fuel pump is on the way out or you have a restriction in the fuel line. Are you running 8mm (plus) lines ? Just a thought.
Mitch.
bbdond
Re: 1ggte fuel pump Sun, 16 May 2004 15:17 Go to previous messageGo to next message
Im using a VL pump in mine mate, no probs Very Happy
it seems to be doing the trick!
runnin a bit rich though Mad
Darkstar
Ebbw Vale, Qld
Re: 1ggte fuel pump Tue, 18 May 2004 01:59 Go to previous messageGo to next message
hey bugman, how much for the pump?
Bugman
Re: 1ggte fuel pump Tue, 18 May 2004 05:20 Go to previous message
around 150
Previous Topic:Wierd 5S-FE oil breather?
Next Topic:stupid question
Current Time: Mon Nov 2 03:35:04 UTC 2026
Total time taken to generate the page: 0.0052621364593506 seconds
