Classifieds » Parts Wanted » 18rg heater bypass metal pipe fitting
munki
Gold Coast
18rg heater bypass metal pipe fitting Fri, 14 May 2004 12:20 Go to next message
Hi
i am after the metal pipe coolant line that goes across the front of the timing case on the 18rg. It is part of the heater bypass line from the waterpump outlet to the tapped pipe on the side of the thermostat housing. Hopefully someone knows what i mean.
Daniel
people100
Rocklea qld
Re: 18rg heater bypass metal pipe fitting Fri, 14 May 2004 22:55 Go to previous messageGo to next message
Good luck..unless you find someone with a wrecked motor that they will strip then you need to make one(thats what i have to do). If you do find one get one for me to Surprised If not how urgent are you for it...Ill make one for you when i make mine...But thats in a few weeks yet..
Mr DOHC
Re: 18rg heater bypass metal pipe fitting Sat, 15 May 2004 03:16 Go to previous messageGo to next message
just fuck it off and get a peice of hose
munki
Gold Coast
Re: 18rg heater bypass metal pipe fitting Sat, 15 May 2004 10:42 Go to previous messageGo to next message
yeah i have a piece of hose there now but i would like the metal bit so i can fir on my 18rc brand new pump and housing.
people100
Rocklea qld
Re: 18rg heater bypass metal pipe fitting Sat, 15 May 2004 11:04 Go to previous message
U wont fit the 18rc housing on there as it has different size pipes. Use the rg housing with the actually rc guts of the pump...And then u can just use a hose stull until u find the pipe.
Previous Topic:4AGE RWD Heater Water Outlet
Next Topic:AE82 parts wanted
Current Time: Thu Nov 19 11:40:48 UTC 2026
Total time taken to generate the page: 0.0059890747070312 seconds
