Toymods » Tech & Conversions » 5mge crank pulley wont sit nicely
STR8 2.8
5mge crank pulley wont sit nicely Sat, 15 May 2004 07:43 Go to next message
Just dropped in a 5mge, in place of the 5me.
Problem:
when i tighten the new crank pulley up it squishes right up against the timing case so hard that teh engine wont even turn over.
There is no gap.
The odd thing is, the original pulley (which is now broken) has had the rear face machined, with the metal and rubber removed.
Can anyone think of a reason why this would have been done?
something missing in the timing gear?
im stumped.
[Updated on: Sat, 15 May 2004 07:44]
STR8 2.8
Re: 5mge crank pulley wont sit nicely Sat, 15 May 2004 14:22 Go to previous messageGo to next message
bump Sad
YelloRolla
On your mum!
Re: 5mge crank pulley wont sit nicely Sat, 15 May 2004 23:21 Go to previous messageGo to next message
Maybe the wrong pulley, maybe something missing, maybe the incorrect timing cover. I would be checking the pulley alignmet with a straight edge and ruler to see how close it is.
Apart from that; it is a difficult problem to work out without seeing it, and without specific knowledge of the engine in question.
rsdeo
Burlington, On. Canada
Re: 5mge crank pulley wont sit nicely Sun, 16 May 2004 00:03 Go to previous messageGo to next message
On the three MA6x cars I have owned none had rubber on the harmonic balancers. I think you have the wrong one.
STR8 2.8
Re: 5mge crank pulley wont sit nicely Sun, 16 May 2004 06:24 Go to previous messageGo to next message
the rubber is impregnated.
to dampen the vibrations- i.e. harmonic balancer
i know the pulley is right, i haev compared it with other known 5mge ones.
yellorolla- not sure what you mean about alignment..
yes it is diffuclt and most annoying.
an incredibly simple conversion just keeps getting more and more complicated Crying or Very Sad
STR8 2.8
Re: 5mge crank pulley wont sit nicely Sun, 16 May 2004 06:46 Go to previous message
think i have found the solution.
the engine originally had the two v-belt alternator belt setup, so it was supposed to use this style crank pulley.
but somewhere along the way, pulleys got broken, and were replaced with ribbed alternator belt style pulleys.
so the new crank pulley had to be machined to fit the old style.
so you guys were right, the pulley is wrong. Embarassed
thanks for ur help
Previous Topic:koni's for ta22 with XT130 struts
Next Topic:2t/3tg hyrbid
Current Time: Mon Nov 2 09:48:35 UTC 2026
Total time taken to generate the page: 0.077294111251831 seconds
