Classifieds » Miscellaneous » G-series 3.72 LSD center
hiaaa
G-series 3.72 LSD center Sun, 16 May 2004 23:23 Go to next message
Hi I got a G-series LSD center for sale, 3.72 ratio, out of a 01 model Hilux, only done 25,000km from new. $550 ono. pick up in Sydney.
[Updated on: Mon, 17 May 2004 08:54]
V8_MA61
Re: G-series 3.72 LSD center Mon, 31 May 2004 08:32 Go to previous messageGo to next message
is this the model with IFS?
hiaaa
Re: G-series 3.72 LSD center Mon, 31 May 2004 23:50 Go to previous messageGo to next message
Yes.
V8_MA61
Re: G-series 3.72 LSD center Tue, 01 June 2004 07:34 Go to previous messageGo to next message
ok mate ill get back to you asap Smile
its the whole centre casing yes?
Fattony
Re: G-series 3.72 LSD center Tue, 01 June 2004 07:40 Go to previous messageGo to next message
Look i might be wrong here but dont newer model hilux come with 'A' series diffs, well thats what it says on the build plate, let me know if i an mistaken on this point.
V8_MA61
Re: G-series 3.72 LSD center Tue, 01 June 2004 07:42 Go to previous messageGo to next message
yes please clarify if that is the case!
hiaaa
Re: G-series 3.72 LSD center Tue, 01 June 2004 09:59 Go to previous messageGo to next message
Yes it is the whole centre casing.
Yes it says A on the build plate, that's the new code for "G" series diff, and it is a G-series diff and will fit any G-series housing (100% sure).
BLACK_JZA
Re: G-series 3.72 LSD center Thu, 03 June 2004 14:29 Go to previous messageGo to next message
will that fit on a MA61 celica supra??
bbaacchhyy
Re: G-series 3.72 LSD center Thu, 03 June 2004 14:35 Go to previous messageGo to next message
Not easily. MA61's are F series which is 7.5", and G's are 8"
BLACK_JZA
Re: G-series 3.72 LSD center Thu, 03 June 2004 14:40 Go to previous messageGo to next message
ahh crap... do u know where i could find one of those?? i need it asap
wil8115
Seattle area, USA
Re: G-series 3.72 LSD center Wed, 16 June 2004 03:09 Go to previous messageGo to next message
pay for overseas shipping?
there is one at the local wreckers.
IRS type F code LSD center. whole casing.
No sure on gears tho.
Jonny2TG
Tasmania
Re: G-series 3.72 LSD center Wed, 16 June 2004 07:55 Go to previous messageGo to next message
The new HiAce vans still use the old diff code. They have a G282 diff. (8" 4.3:1 open). That is RZH113 vans and the like.
It seams every other vehicle has gone to the new mysterious diff code. I havn't worked it out yet. B at the end means LSD, A means open.
New HiLux 2wd's have a A01A diff code. This is RZN149, RZN154 etc.
New HiLux 4wd's have a A03B diff code from memory. But I don't think you can just call it a "A" series diff. Something else is up with the code. eg:
FZJ105 'Cruiser = A04B
GRJ120 Prado = A03B
SR40 Spacier van = A03A
RZN154 hilux = A01A
HZJ75 'Cruiser = K085 (old code)
MX83 (7M-GE) LSD = G315 (old code)
New Corolla (south africa) diff code = G770
Shotgun
Auckland, New Zealand
Re: G-series 3.72 LSD center Thu, 17 June 2004 14:31 Go to previous messageGo to next message
hiaaa wrote on Tue, 01 June 2004 21:59
Woah woah woah. That's a big call! You sure? Are you suggesting G/A interchangability?
I hope you're right cos that means I can source a cheap LSD for my JZZ30 (A diff) instead of a NZ$1600 TRD one.
[Updated on: Thu, 17 June 2004 14:32]
V8_MA61
Re: G-series 3.72 LSD center Fri, 18 June 2004 07:41 Go to previous messageGo to next message
thats wrong...otherwise why would the new supras also have an A series centre, if its the same as the ma70's G series?
hiaaa
Re: G-series 3.72 LSD center Fri, 25 June 2004 14:12 Go to previous messageGo to next message
I don't know much about the IRS diff and the new codes, but I know the 2001 Hilux diff can bolt on to the 1975 model Hilux diff housing, and run.
soarer21
Toymods Forum Sponsor
Re: G-series 3.72 LSD center Sat, 26 June 2004 03:07 Go to previous messageGo to next message
Having done that exact swap recently I can confirm hiaa's statement that his diff fits early G series Hilux housings.
V8_MA61
Re: G-series 3.72 LSD center Sat, 26 June 2004 07:26 Go to previous messageGo to next message
BLACK JZA i have one in my garage...
[Updated on: Sat, 26 June 2004 07:27]
V8_MA61
Re: G-series 3.72 LSD center Sat, 26 June 2004 07:28 Go to previous messageGo to next message
soarer21 wrote on Sat, 26 June 2004 13:07
John, so will that fit all in my ga70 centre?
Stenno
Re: G-series 3.72 LSD center Sat, 26 June 2004 12:01 Go to previous messageGo to next message
Gxx9 (Torsen) compared to BxxB centre.
Both A and G centres run a 200mm crown wheel whilst the B series runs a 220mm crown wheel.
http://www.turbosupras.com/images/technical/G%20vs%20B/G%20vs%20B%204.jpg
hiaaa
Re: G-series 3.72 LSD center Mon, 30 August 2004 07:36 Go to previous messageGo to next message
Bump
V8_MA61
Re: G-series 3.72 LSD center Mon, 30 August 2004 07:59 Go to previous messageGo to next message
can i have pics of the mentioned diff for sale please.
rneil@bigpond.net.au
dingaling
tas
Re: G-series 3.72 LSD center Mon, 30 August 2004 10:25 Go to previous messageGo to next message
pics here aswell urantiacjd@dodo.com.au
can i use my 3.9 open diff to use this center and have a 3.9 LSD? the gear ratio is determined from the crown wheel and pinion right?
V8_MA61
Re: G-series 3.72 LSD center Mon, 30 August 2004 12:57 Go to previous messageGo to next message
give me the gearset then please Wink if you decide to go ahead and buy it before me
dingaling
tas
Re: G-series 3.72 LSD center Mon, 30 August 2004 13:08 Go to previous messageGo to next message
sure thing blake, if i get this LSD you can have the 3.72 gears. So i take it what i suggested is correct?
using this LSD center in my 3.9 open diff to make a 3.9 LSD? everything a straight swap? no changing of axles etc? it's all the same fittings? fuck i wish i knew about this stuff.
V8_MA61
Re: G-series 3.72 LSD center Mon, 30 August 2004 13:28 Go to previous messageGo to next message
dingaling wrote on Mon, 30 August 2004 23:08
to my knowledge its all interchangeable. Do some more research before committing tho Wink
Whats the 3.9 out of? MA70 turbo manual?
dingaling
tas
Re: G-series 3.72 LSD center Mon, 30 August 2004 14:27 Go to previous messageGo to next message
yeah i've searched and searched and i can't any info regarding open to LSD center swaps with G series diffs. any links would be great!
The 3.9 is out of an MA70 turbo Auto. The car is a Limited GT supra, whatever that means, i would of expected it to have an LSD standard.
mx83toy
Re: G-series 3.72 LSD center Tue, 31 August 2004 09:39 Go to previous messageGo to next message
is this LSD a Torsen or Clutch type?
V8_MA61
Re: G-series 3.72 LSD center Tue, 31 August 2004 09:58 Go to previous messageGo to next message
whoever buys it, i want the gearset Wink
I would prefer a powertrax lsd anyway Smile
mx83toy
Re: G-series 3.72 LSD center Wed, 01 September 2004 02:45 Go to previous messageGo to next message
powertrax??? enlighten me Very Happy what that????
V8_MA61
Re: G-series 3.72 LSD center Wed, 01 September 2004 07:17 Go to previous messageGo to next message
http://www.rocky-road.com/noslip.html
[Updated on: Wed, 01 September 2004 07:22]
Danish
Re: G-series 3.72 LSD center Wed, 01 September 2004 08:32 Go to previous messageGo to next message
Stenno, my Torsen G series LSD is the one on the left.
So that definately will fit in my GZ20 housing? Code: G284.
mx83toy
Re: G-series 3.72 LSD center Wed, 01 September 2004 10:16 Go to previous message
interesting looking thing that one... do they free up like a clutch lsd? what are they worth??? the torsen has been a great thing in my car and am hesitent in replacing the thing....
Previous Topic:FS: 4AGE Twincam engine & ECU - AE82 *SOLD*
Next Topic:AE86 levin tail lights
Current Time: Wed Nov 25 21:52:06 UTC 2026
Total time taken to generate the page: 0.0087809562683105 seconds
