Toymods » Tech & Conversions » Why replacing oil and filter is good
RWDboy
Why replacing oil and filter is good Mon, 17 May 2004 06:11 Go to next message
Well, this is actually a question, but first is a demonstration of why you should replace the oil and the oil filter as per the toyota servicing schedule...unless you too want piston rings that are so full of carbon deposits that they are seized in allowing the engine to burn more oil than the Iraqi military fleeing the UN.
click for larger image
http://members.austarmetro.com.au/~pwade/5SFE_rings_effed_s.jpg
And now for the second image I have a question. Is the discolouration (it's slightly goldish looking) simply a result of the oil getting cooked by combustion gasses? Possibly the result of old oil and the fact that the car that this came from was burnt to the ground?
http://members.austarmetro.com.au/~pwade/5SFE_discolor_s.jpg
RobST162
Re: Why replacing oil and filter is good Mon, 17 May 2004 06:40 Go to previous messageGo to next message
when oil burns it does that funny goldish colour thing to some metals from what I have seen
dipsticks go that way too...
ALWAYS CHANGE YOUR OIL! Wink
RWDboy
Re: Why replacing oil and filter is good Mon, 17 May 2004 06:48 Go to previous messageGo to next message
Yep - always change oil!!! Luckily this is out of a wrecked car (I would never let this happen to my car!) and hence I don't have to claim responsibility for this.
You can see that those rings (ALL THREE OF THEM) are completely stuck in and wouldn't seal for shit. Only about 4 combustion rings were still floating out of the 8 in total, and none of the 4 oil rings were floating at all.
This is how engines end up blowing a tonne of blue smoke Crying or Very Sad
SupraPete
Re: Why replacing oil and filter is good Mon, 17 May 2004 06:55 Go to previous messageGo to next message
Can it be fixed? Can you dribble something into the sparkplug hole that will take away those deposits and start the rings floating again?
Or is the only option to strip it and re-ring?
RWDboy
Re: Why replacing oil and filter is good Mon, 17 May 2004 07:16 Go to previous message
Not sure - I would say that the best option is to pull it apart and re-ring it. It wouldn't hurt to try decoking it (using ed_ma61's patented vacuum hose + redex technique). It probably wouldn't be 100% effective though. You really only have to worry about this kind of thing if you never change your oil filter.
In this example, I would say strip and re-ring is the only 100% guaran-damn-teed to work option...I'm not even going to use these pistons + rings
Once I've cleaned 'em up, if anyone wants a set of low kms 5S-FE pistons in Adelaide...wait a minute what am I saying - who would want 5S-FE pistons?!!?!!?!
Bwahahaha...
[Updated on: Mon, 17 May 2004 07:19]
Previous Topic:What gearbox/ bellhousing do i have?
Next Topic:KE25 - KE35 difference?
Current Time: Wed Nov 18 14:02:07 UTC 2026
Total time taken to generate the page: 0.0046219825744629 seconds
