Toymods » Tech & Conversions » Help toyota corona st141 transplant
toyotacorona
melb
Help toyota corona st141 transplant Mon, 17 May 2004 14:33 Go to next message
Hi i have manged i grab a toyota corona st141 1986 i need some help i am not shore with what engine i should but in it i am looking for mostly a bolt in. its an autobox but i would'nt mind changing it thx sam
jackel
Re: Help toyota corona st141 transplant Mon, 17 May 2004 15:47 Go to previous messageGo to next message
doing a search on "st141" will give you alot of info on what you want but if you want a "bolt on" then only another corona engine will do.
If you want something bigger and better and have a few thousand to spend go a 3T-GTE or a 1G-GTE
as if you want a manual either find a corona with the same engine that is manual and swap everything over or if you want another engine, then get a halfcut and that will come with a gearbox but make sure it's manual
Re: Help toyota corona st141 transplant Tue, 18 May 2004 00:09 Go to previous messageGo to next message
I'd be saying 1GGTE, if it's within your budget Evil or Very Mad
7M-Brisbane
Re: Help toyota corona st141 transplant Tue, 18 May 2004 00:58 Go to previous message
I have put a 1GGTE into one of these. The car was fantastic to drive once completed, and it is a fairly easy conversion. Probably not ideal if you want something to handle well, and it is a very tight fit due to the length of the six cylinder.
Personally if I was doing it again, I would use a 13BT or a 1UZFE. The engine bay is rather large, but would want to do some pretty comprehensive measurements before buying a 1UZ in case it doesn't fit. Note that for all intents and purposes you will be stuck with an auto behind the 1UZ.
Nothing will be a simple conversion, except maybe putting in another 2S. If you have heaps of money I'd say that the 3SGTE is your ideal swap but it's VERY expensive and about as far from 'drop in' as you can get.
Previous Topic:1ggte injector upgrade
Next Topic:ae86 hanging its ass too much
Current Time: Thu Nov 5 05:03:51 UTC 2026
Total time taken to generate the page: 0.035235166549683 seconds
