Toymods » Tech & Conversions » 1g-gte smoking
indian
south east - melbourne
1g-gte smoking Tue, 18 May 2004 23:13 Go to next message
hey fellas noticed this for a week now after returning from work and starting the car to go home from the station the car lets out a little puff of smoke and then nothing
but when i drve it and floor the car and it comes on boost i can see smoke in the rear view mirror but cant really tell what colour as its night time by then looks like blackish grey smoke
are my turbos on the way out
the turbos have a loud squeal and lets outthis hissing/whistling noise when let go off the accelerator after flooring it Confused Confused Confused
Danners
Central Coast, NSW
Re: 1g-gte smoking Tue, 18 May 2004 23:18 Go to previous messageGo to next message
The first puff of smoke would be your valve stem seals... the smoke coming from the car when you accelerate is FAIRLY normal depending on how much there is... remember that turbo cars are dirty cars - then theres the squeeling! i don't like the sound of that at all
Dan
indian
Re: 1g-gte smoking Tue, 18 May 2004 23:27 Go to previous messageGo to next message
gees will valve stem seals cost a lot to fix , i dun know how to do it , so will need to go to mechanic
the squeal i meant was the turbos spooling up but they are a bit loud can hear in the car with the windows closed
also to make it more understandable , if i rev the car when its idling when it at normal operating temp theres no smaoke to be seen nothing at all
only appears when i start it up first time after work in the evening , then when im driving home if i floor it its got smoke coming out the zorst when on boost , not sure if that unburnt fuel or oil
when i start the car to go to work i the morning i havnt noticed any smoke it only happens when i come back from worjk in the evening and start the car
could it be happening cause the car is left out in the cold when im at work
car is garaged when its at home so it less likely to get colder Sad Sad Sad Sad Sad
[Updated on: Tue, 18 May 2004 23:33]
gold28
Madrid - Spain
Re: 1g-gte smoking Wed, 19 May 2004 00:15 Go to previous messageGo to next message
Yup it sounds like the valve stem seals are starting to go.
I wouldn't worry about it too much, just keep an eye on your oil level. If your really concerned, you could get them replaced. I think they cost about $8 each from toyota multiplied by 24 valves gives you close on $200 just for the seals. Most mechanics will want to remove the head to do it, meaning more gaskets, lots of time and while the head is off you may as well get it serviced and the valves lapped. Don't expect too much change from $1K.
Or as I said earlier, don't worry about it. It will only be noticeable as a puff of smoke on startup for a couple of years. Just make sure all thoes little puffs don't result in an empty sump.
indian
Re: 1g-gte smoking Wed, 19 May 2004 00:19 Go to previous messageGo to next message
HOLY SMOKESSSSSSSSSSSSSS
DAMN 1k thast gonna rip my underpants wallet and all apart
gees wasnt expecting that
so i can still drive car , but just keep filling the oil up
so whats with the car smoking at boost ?????????????? Sad Sad Sad
gold28
Madrid - Spain
Re: 1g-gte smoking Wed, 19 May 2004 01:32 Go to previous messageGo to next message
If it is just the valve stems, don't panic, I drove around for 18 months on my last 1G with leaking valve stems. It is just a sign of the engine ageing. If you don't mind a puff of smoke on startup then don't worry about it. If you do, then fix it. The joys of owning an old car mate.
If your seals are just starting to go, then you probably wouldn't notice the small amount of oil loss, so just do your normal oil checks and you shouldn't have to worry any more.
The "smoke" on boost is probably just the engine running rich and it would have done this since new and you haven't noticed until now. It may be your turbo oil seals but we can't tell unless we see it.
If you are concerned, why not take it to a mechanic and get him/her to look at it. They are not all evil you know.
Looonie
Auckland, NZ
Re: 1g-gte smoking Wed, 19 May 2004 07:35 Go to previous messageGo to next message
Just to add my 2c Smile
My 89 GZ20 Soarer with 1G-GTE does basically exactly the same... a puff of blue smoke when I start it up, resulting in need a litre every couple of weeks. And when I floor it I get clouds of brown/black smoke out the back and my rear bumper is caked in SHITE... REALLY annoying :\
I'm in the process of trying to solve the soot issue as I don't think its natural, so I'll try and let you know how I get on... as for the valve stem seals, well fuck it, 1k is coilovers and I know which I'd rather spend 1k on Very Happy
indian
Re: 1g-gte smoking Wed, 19 May 2004 22:38 Go to previous messageGo to next message
F***ing awsome mate , this thing only recently started and has got me buggered
ive got very expensive synthetic oil in the car , i think iil just use normal oil
does ur car smoke after its gotten to normal operating tempperature , as i havnt seen any smoke after the car has the temperature gauge in the half waqy mark which is normal
what i dun understand is my car has only done 78,000 Confused Confused Confused kms Crying or Very Sad Crying or Very Sad Crying or Very Sad Crying or Very Sad Crying or Very Sad
gold28
Madrid - Spain
Re: 1g-gte smoking Wed, 19 May 2004 22:47 Go to previous messageGo to next message
Just to state the obvious, are you sure it is not just steam??
indian
Re: 1g-gte smoking Wed, 19 May 2004 22:49 Go to previous messageGo to next message
yeah its defenitly some inda smoke and not steam , its bluish colour and comes straight away as i start the car , the steam comes after another 5-6 seconds
Looonie
Auckland, NZ
Re: 1g-gte smoking Thu, 20 May 2004 00:29 Go to previous messageGo to next message
With regards to the blue smoke at start up, its a puff of blue smoke as soon as I start the car (definite blue, not white) and if I drive it straight up the driveway it'll puff more blue smoke out, but once its warmed up a bit and got the oil circulating it stops smoking blue (only about 20-30 seconds till it stops)
The other thing I've noticed is after a fresh oil change it doesn't do it, but as I'm changing my oil about every 4000kms I'm not gonna change more frequently just for that... just means I ahve to top up every fortnight in between changes...
My car had only done 113,000kms when I picked it up, although I suspect its been deregistered and re registered so probably was sitting around for a year doing nothing which wouldn't have helped the seals at all...
indian
Re: 1g-gte smoking Thu, 20 May 2004 00:38 Go to previous messageGo to next message
lollllllllll mines been sitting in the backyard for about 2 years in the harsh melboure weathe , so i guess thats whats happened , and now since ive started using it its getting worn quickly Crying or Very Sad
ddeane
PNG
Re: 1g-gte smoking Thu, 20 May 2004 03:03 Go to previous messageGo to next message
I assume that you have the boost wound up! If you get the car on the dyno you will find that at boost levels above 9-10psi the thing starts to run so rich it does not matter. Mine was in the order of 10.5 air/fuel ratio. The black smoke is unburnt fuel. While I am not recommending that you just go ahead and just do this - I found that by disconnecting the vacuum/boost line to the 'rising rate' fuel regulator I was able to achieve better air/fuel ratios. I did this on a dyno to confirm that the car was not leaning out anywhere. Not only did the car put out 10kw more at the wheels the driveability was vastly improved. As I said make sure that you check the result on a dyno.
Craig
indian
Re: 1g-gte smoking Thu, 20 May 2004 03:07 Go to previous messageGo to next message
MY CAR IS STOCK AS A ROCK Very Happy
ddeane
PNG
Re: 1g-gte smoking Thu, 20 May 2004 05:29 Go to previous messageGo to next message
some things wrong! First place to look would be fuel pressure.
indian
Re: 1g-gte smoking Thu, 20 May 2004 05:36 Go to previous messageGo to next message
well im thinking of doing something soon ,
the first puff of smoke is defenitly blue , the other i cant really see as im driving , ad looks very much blackish brown
im thinking of getting a safc soon so i will get itdynoed and tuned then
car runs ok otherwise
i have als noticed sometimes usually at cold running temperature at standstill the car sorta gets a bit stuck when taking off at the lights , u can feel the car sluggish only very tiny bit , then takes off , it happens only for the first 1/2 a second or so when taking off after a perfect standstill
nly if i take off very slow can u notice it , if the car is given enuf juice it goes as normal
Toobs
Re: 1g-gte smoking Thu, 20 May 2004 05:54 Go to previous messageGo to next message
Try using a slightly thicker oil... fully synthetics can be quite thin (e.g. 5W30)... If you use a really thin oil with slightly crap vss's you will smoke more
indian
Re: 1g-gte smoking Thu, 20 May 2004 06:07 Go to previous messageGo to next message
ya ive been from 5w-50 , to 10w-50
no im going to 15 w cause i think that will suit my old car better
fully synthetic is too thin for a 1988 model car as well as the car wasnt made to run on them anyway
Looonie
Auckland, NZ
Re: 1g-gte smoking Wed, 26 May 2004 22:25 Go to previous message
ddeane wrote on Thu, 20 May 2004 15:03
Craig
On an interesting note, now that I've done my manual conversion the car doesn't seem to smoke as much when I floor it. Albeit the battery was disconnected for 3 days so perhaps an ECU reset fixed the problem. Also I haven't directly wound the boost up, its a Gen 3 1G-GTE so 11psi standard anyway, with 3" exhaust and no filter. If I get a chance to dyno it I'll try disconnecting the vacuum line to the FPR... I am however planning to install a boost kit and get around 1bar (maybe a little higher for testing *evil grin*) but we'll see how I go, I want it on the dyno once I've done that to check where optimal boost level will be...
Previous Topic:1ZZ conversion is it possible
Next Topic:4age 20 valve VS 4AGZE
Current Time: Sun Oct 18 08:02:46 UTC 2026
Total time taken to generate the page: 0.029632806777954 seconds
