Toymods » Tech & Conversions » 4age fuel line help pls
Hunty
4age fuel line help pls Wed, 19 May 2004 03:28 Go to next message
Hey, i've swapped out my 4ac from the ae82 and dropped the 100kw 4age in and i've swapped the fuel lines to the new fatter ones but im not sure which ones go where there are 2 smaller ones breather, and return? and then the bigger one which is the main fuel line. With the two other ones where do they hook up to?
on the old ones one went to a pipe at the back of the car and that looked like it when up towards the filler then came back down and split into 2. I'm assuming that one of the two pipes gets hooked up the bottom of the charcoal canister, im guessing this is the breather? and the other one, the return?, to the engine where there is that little diaphram thingy. but im wondering which one goes up and splits into the two pipes at the back of car the return? or the breather?
Cheers for any help
IRA11Y
Club Member
Re: 4age fuel line help pls Wed, 19 May 2004 10:10 Go to previous messageGo to next message
all three pipes are seprate, there is no two in to one pipeing, use the one at the charcoal canister as the breather, the small one on the fireall can be used as the return from of the fuel pressure regulator. Alternatively if your worried about return flow you can swap these two, keep the exsisting fuel pickup as just that.
at the tank end just get somone to blow down one of the two big lines to determine which is the source and which is the breather, and dont mix them up when you install the pump.
Hunty
Re: 4age fuel line help pls Wed, 19 May 2004 23:17 Go to previous messageGo to next message
yes all 3 lines are separate. BUT at the back of the car, one of the old 4ac fuel lines hooked up to a rubber hose pipe that went up along side the filler up towards the filler cap and then came back down as two pipes. ie blow air down one pipe at the front of the car which is connected to this rubber hose and the air comes out two pipes at the rear of the car. thats what im confused about or should i just ignore that completely and just plug the return and breather pipes to the fuel tank directly?
Thanks again
IRA11Y
Club Member
Re: 4age fuel line help pls Thu, 20 May 2004 09:17 Go to previous messageGo to next message
just use them as the breather as thats clearly what they are then.
Re: 4age fuel line help pls Fri, 21 May 2004 07:10 Go to previous message
i never touched the fuel lines on my AE71....
Previous Topic:What to do next???
Next Topic:Going from panel filter to pod
Current Time: Mon Oct 26 12:52:34 UTC 2026
Total time taken to generate the page: 0.017843008041382 seconds
