Toymods » Tech & Conversions » ae86 heater - help please
des_
ae86 heater - help please Wed, 19 May 2004 05:27 Go to next message
I've just got my car registered, applause, but the heater dosent seem to be producing any heat, which is a bit of an issue seeing as its starting to get cold.
how does the heater actually work, ie produce the heat (it pushes air fine) is it electrical or mechanical? all the electrical components of it seem to be in order. if anyone has any troubleshooting solutions they would be most helpful, thanks.
des
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: ae86 heater - help please Wed, 19 May 2004 06:09 Go to previous messageGo to next message
Okay, sorta like how your radiator works, water passes through your heatercore(tiny version of ur rad). When you slide your temperature control thing, you are actually opening a tap to allow hot water to enter this heat exchanger. Air pushes thru it and BAM! Hot air is made Smile. Hence why you will notice why your heater doesnt work when the engine is cold.
Quite often the tap will jam or get stuck due to corrosion. I'm pretty sure its only made of copper or brass. Other things that may cause it to not produce heat is the heater core is clogged and sometimes just the rubber hoses are clogged.
You should be able to see two rubber hoses connecting to tubes on your firewall (thing that seperates you from the engine bay). Try squeezing the hoses when the car isnt running and preferably cold. If it feels/sounds crunchy, then the tap or something else has corroded and you need to open her up.
Christ I maybe wrong, someone please tell me I'm right Smile
Henn
Rosanna, Melb
Re: ae86 heater - help please Wed, 19 May 2004 07:26 Go to previous messageGo to next message
You're right.
The tap should be mounted on the firewall in the engine bay, just beside your clutch master cylinder.
lang
Re: ae86 heater - help please Wed, 19 May 2004 07:32 Go to previous messageGo to next message
try pushing the lever from the cold position to the hot position Laughing Laughing Laughing
Flogbag
Sydney (Campbelltown...!)
Re: ae86 heater - help please Wed, 19 May 2004 07:36 Go to previous messageGo to next message
disconnect a heater hoes and run your engine and see if it pushes coolant thru the heater core
* dont do when hot or run motor for a long period
ae86drift
sydney.au
Re: ae86 heater - help please Wed, 19 May 2004 07:56 Go to previous messageGo to next message
lang wrote on Wed, 19 May 2004 17:32
theres always one.... Rolling Eyes
des_
Re: ae86 heater - help please Wed, 19 May 2004 09:00 Go to previous messageGo to next message
always one what?!?
lang hit the snail on the shell, gold rotor for you.
who would have thought i'd forgotten to check that silly little lever on my dash glaring warm at me but not giving it up.
Rolling Eyes
anyway thanks guys, im just about to rip everything apart and see whats up. ill report findings.
ae86drift
sydney.au
Re: ae86 heater - help please Wed, 19 May 2004 09:25 Go to previous message
Flogbag wrote on Wed, 19 May 2004 17:36
how did you go with that strut brace bud?
Previous Topic:3TGTE - Power/fuel difference with tune up
Next Topic:Radiator info needed on ST141 ??sa63??
Current Time: Sat Nov 21 04:56:44 UTC 2026
Total time taken to generate the page: 0.0062539577484131 seconds
