Toymods » Tech & Conversions » 3sgte turbo manifold
rozz
3sgte turbo manifold Wed, 19 May 2004 08:29 Go to next message
hey guys, can anyone out there tell me if a 3s-gte turbo manifold off a GT4 Etc. will fit on to a 5s-fe, or if there is any other turbo manifold that would fit, would save me getting a custom one made up
wagonist
Toymods Club Treasurer
Re: 3sgte turbo manifold Wed, 19 May 2004 23:15 Go to previous messageGo to next message
Which GT4?
Where is your oil filter?
The ST205 & later ones probably won't because the oil filter was relocated to the sump to allow for a bigger turbo, manifold, dump pump. I think the MR2 one is different too (but only because of the position)
The earlier ones I've heard are a straight bolt on.
Just remembe to keep the boost down if you're not going to open up the engine & replace bits,
otherwise you will be replacing bits.
spectral
Re: 3sgte turbo manifold Wed, 19 May 2004 23:32 Go to previous messageGo to next message
here are some pics that may help you :
Exhaust manifold off a Gen 2 3SGTE:
http://www.amberaspley.com/gt4/pics/3SGTE/before/T winEntryTurboManifold.JPG
Exhaust ports off a Gen 2 3SGTE :
http://www.amberaspley.com/gt4/pics/3SGTE/before/V alves.JPG
The other ports are the same bolt pattern, except there is a 7th bolt in the middle at the top of the manifold..
Distance pic here:
http://www.amberaspley.com/gt4/pics/3SGTE/on-stand /exhaustside.jpg
rozz
Re: 3sgte turbo manifold Sat, 22 May 2004 00:29 Go to previous messageGo to next message
yeah thanks for that i will have a look and hopefully it will fit
i will be pulling the engine down and doing a fulkl rebuild with low compression pistons and port and polish, and possible some valve work, everything else like the crank and the conrods can handle over 14psi, i'm only really looking at about 10psi
Celebdae
Texas
Re: 3sgte turbo manifold Thu, 03 June 2004 07:41 Go to previous message
Yes, it will fit. Many of the NA guys over here bolt the 3sgte exhaust manifolds onto the 5sfe. The NA variant of the MKII MR2 over here uses the 5sfe. Bolts directly on.
Previous Topic:MA61 Gear Ratios
Next Topic:KE1x Corolla Front Brake Upgrade Information
Current Time: Thu Oct 15 10:41:46 UTC 2026
Total time taken to generate the page: 0.0084228515625 seconds
