Toymods » Tech & Conversions » TA22 intercooler ideas?
TA22
TA22 intercooler ideas? Wed, 19 May 2004 08:55 Go to next message
as my GT project is nearing im going to need to get an intercooler, does anyone have any ideas to help me out?
where should the piping go, and whats a good size. what have others done?, thanks.
Syc02T
Lake Macquarie
Re: TA22 intercooler ideas? Wed, 19 May 2004 12:52 Go to previous messageGo to next message
i dont know how to load pics, but i will email one of the front of what i did to mine when i got it painted. also a front shot of the cooler
TA22
Re: TA22 intercooler ideas? Wed, 19 May 2004 15:35 Go to previous messageGo to next message
thanks for the pics, ur car looks shmick
is it legal to cut into the front frame like that? cuz thats how the previous owner cut into mine too
where abouts are u registering the car?
cuz im in Melb
TA22
Re: TA22 intercooler ideas? Wed, 19 May 2004 17:02 Go to previous messageGo to next message
by the way, what size cooler u got?
Syc02T
Lake Macquarie
Re: TA22 intercooler ideas? Thu, 27 May 2004 04:06 Go to previous messageGo to next message
As long as there are no sharp edges to cut inquisitive fingers and it doesn't take away from the strength, its generally OK.
Best bet is to talk to the engineer, as they will tell you what they require, they have the last say anyway.
as for the size, it is a PWR at a custom size. it was measured up to just fit without cutting any bumpers etc. cant remember the size but it is about 400 x 400 at the widest of the tanks, the core is about 330 i think.
I can measure if you want the exact details.
TA22
Re: TA22 intercooler ideas? Thu, 27 May 2004 07:45 Go to previous messageGo to next message
so was it allright with cutting into the front where u cut?
what kind of turbo u running on ur 2tgeu?
i got a 2tgeu in one of my celicas, any idea if they work well with turbs?
Syc02T
Lake Macquarie
Re: TA22 intercooler ideas? Fri, 28 May 2004 04:48 Go to previous messageGo to next message
mate, The turbo i got on mine is a bb t3. it is bigger that the 3tg turbo that i had on there b4 which put out 180hp a wheels on 7psi. i believe they respond well with a bit of forced persuasion like any engine if you look after its requirements for fuel, ignition etc. i hope for a fair bit more hp with this one, especially considering the many times that wallet has opened lately.
Have to admit the engineer hasn't had a final thumbs up yet, i just told him what i was doing and he thought it was ok, but also my dad is a mechanical engineer so i followed his guidelines with that one. should be ok tho
ENVYS-SR20
Re: TA22 intercooler ideas? Fri, 28 May 2004 07:05 Go to previous messageGo to next message
hey TA22..
i looked into this a fair bit when i put the cooler in my car. if your lookin for an off the shelf item, the only one that i found to fit was the mitsubishi VR4 cooler. With this cooler there was minimal cutting involved, only a 10-cm strip had to be cut from the lower plastic lip, and u can even use the mounting points that come on the standard VR4 cooler, as they line up with sum existing bolts on your celica. price is bout 450 for the cooler, and the cooler can take easy take 230+rwkw
adam
TA22
Re: TA22 intercooler ideas? Fri, 28 May 2004 15:54 Go to previous messageGo to next message
yeh the only problem is that the holes have already been cut, and look very similar to the holes cut into syco2ts front. have a look at the pics on my website of the ta22GT front
Syc02T
Lake Macquarie
Re: TA22 intercooler ideas? Tue, 29 June 2004 10:44 Go to previous messageGo to next message
I finially got the car to the engineer yesterday, he had a look at how i cut the holes in the front, it passes because the loads going through the front of the car go through the top removable bar and the fixed cross member underneath the radiator.
Where the holes were cut there was double thickness metal that goes up to the headlights, that was cut, but this was OK because it does not join the the cross member. I must admit he did have a bit of a look tho.
So there you go, thats what i found.
BTW i did not pass the damn test, the engine bay was fine, but i was told that the odyssey battery that i put in the boot had to be in a sealed box, as well as clamped down inside it. I built a mostly wooden box that retained the battery tightly inside it, and made it so that if in an accident, the box would stay around the battery. apparently not good enough.
The other problem i had was that apparently the surge tank and fuel system must be contained in a fire resistant enclosure with venting to the outside of the car. i know of many other cars engineered with the same fuel system, no metal sealed boxes for them, WHY 4 ME!!!
dcving
newcastle nsw
Re: TA22 intercooler ideas? Tue, 29 June 2004 22:06 Go to previous messageGo to next message
because he loves you chris Very Happy Very Happy Very Happy
now pull your finger out and get them things fixed Razz
[Updated on: Tue, 29 June 2004 22:07]
Syc02T
Lake Macquarie
Re: TA22 intercooler ideas? Fri, 23 July 2004 05:41 Go to previous messageGo to next message
I now finially have in my hot little hands an engineers certificate. hip hip horayyyyy.
Now for the blue slip
the intercoller holes were fine by him
fade-e
Re: TA22 intercooler ideas? Fri, 23 July 2004 05:54 Go to previous messageGo to next message
could i get a copy of the IC pic please?
fadee@optusnet.com.au
thanks heaps
also if possiblew could i get a pic of how you did the boot?
TA22
Re: TA22 intercooler ideas? Fri, 23 July 2004 11:30 Go to previous message
congratulations buddy!!
yeh pass some pics around mate, show us this beast on the road Smile
Previous Topic:AE82 more brake boost?
Next Topic:3T GTE TURBO conversion
Current Time: Mon Nov 9 23:38:33 UTC 2026
Total time taken to generate the page: 0.0094969272613525 seconds
