Toymods » Tech & Conversions » oil pressure on idle
ta2272
oil pressure on idle Wed, 19 May 2004 09:40 Go to next message
my oil pressure gauge hardly moved up when on idle and oil is warm.
jason
is this normal. this is well under 1 psi
kingmick
Banned by his request
moved to tamworth
Re: oil pressure on idle Wed, 19 May 2004 10:17 Go to previous messageGo to next message
some old holden motor like 202 etc had 6psi at idle which was ok but it should be over 10 on a toyota motor even an old one. check you gauge or if electric check sender. if its that low at idle it will be low at revs which isnt good. more likely a guege or sender prob but make sure as its a pain in the butt to break down and have to get a tow.
mick
ta2272
Re: oil pressure on idle Wed, 19 May 2004 11:14 Go to previous messageGo to next message
the gauge only goes up to 8 psi i cant see it having such high psi on idle.
jason
Re: oil pressure on idle Wed, 19 May 2004 11:26 Go to previous messageGo to next message
you should have more like 40-60psi when running..
sure it is psi and not some other unit?
or is it 8 (x10) psi?
ta2272
Re: oil pressure on idle Wed, 19 May 2004 11:28 Go to previous messageGo to next message
its just one of those supercheap like 4cm - 3cm black gauges ill go have another look now.
jason
ta2272
Re: oil pressure on idle Wed, 19 May 2004 11:32 Go to previous messageGo to next message
no x marking next to the psi but there is a nother format of pressure it goes up to it is
kg/cm2 and it goes to 5.6
jason
kingmick
moved to tamworth
Re: oil pressure on idle Wed, 19 May 2004 11:35 Go to previous messageGo to next message
think you will find if it only goes to 8 its a kg/cm gauge which is fine to have a reading of 1-2. and 3.5 at revs
mick
shinybluesteel
melbourne
Re: oil pressure on idle Wed, 19 May 2004 12:03 Go to previous messageGo to next message
1 kg/cm^3 roughly equals one bar, or one ATM, which roughly equals 15 PSI
dingaling
tas
Re: oil pressure on idle Wed, 19 May 2004 13:51 Go to previous message
shinybluesteel: thanx for clarifing that, as my supra oil guage only has kg/cm measurment, i was worried my idle at 3-4 kg/cm was way low.
Previous Topic:st141 conversion
Next Topic:2tg efi gear running a 3tg
Current Time: Sat Oct 24 20:37:13 UTC 2026
Total time taken to generate the page: 0.013792991638184 seconds
