Toymods » Tech & Conversions » Recomendations on Toyota Ute for a 1J
1UZ FTE
Recomendations on Toyota Ute for a 1J Wed, 19 May 2004 12:03 Go to next message
Anyone got any good recommendations on what toyota utes would best suit a 1j ,......reg will be in Vic so shouldn't be to hard to obtain if the conversion is kept simple and neat
I don't want to get stuck into cutting fire walls or altering steering etc etc basically looking at just being able to alter the basics,eg engine mounts ,.gearbox cross, radiators, ...exhaust ,... wiring loom etc
My knowledge of toyota ute's sucks but i am open to year models age etc
Dual cabs 4x4 or 2 wheel drives ,.....i'm leaning on the 2wheel drive models though
Any suggestions or Pro's Con's would be great,.....also pics of particular utes
ohh also particular 1j models ,...KW outputs ,..$ figures etc
I presume there is prob several different models
J
CrAiGzEE
south of the big smoke
Re: Recomendations on Toyota Ute for a 1J Wed, 19 May 2004 12:22 Go to previous messageGo to next message
it probably dont fit your requirements of not having to cut/mod stuff but a stout with a 1j would be nice!!
Re: Recomendations on Toyota Ute for a 1J Wed, 19 May 2004 13:09 Go to previous messageGo to next message
Hell yes! Just for the name, AND the look.. I"ll cast another vote for Stout Very Happy
Re: Recomendations on Toyota Ute for a 1J Wed, 19 May 2004 13:13 Go to previous messageGo to next message
have a search - there is a guy around with a 1jz hilux. 1jzs are all fairly similar (except the vvti single turbo) and fuck I dont care anymore
go do a search for 1jz types, it's all explained.
1UZ FTE
Re: Recomendations on Toyota Ute for a 1J Thu, 20 May 2004 02:48 Go to previous messageGo to next message
Thanks for the stout idea guys but i have had a look at a stout and it definatley does not meet the criteria of fitting relativley easy
Draven I have done a search and spent a good 2-3hrs reading any post with the hilux posted little alone 1J all before i posted
I noted that there is plenty of post for a hilux and a 1u but i already have a 1u and would like to play with something different
I was looking for constructive information from someone who may have actaully done a conversion seen a conversion or know the process for a 1j in any toyota ute conversion
eg if you use a single turbo model 1J in a 85model hilux the exhaust will clear the steering box with ease where as a twin turbo model won't fit at all without modification the to the steering
anyway no offence intended to anyone just trying to do the homework before rushing out an buying a ute and a 1J for some fun
Keep anyideas comming as i am keen for this conversion to happen
Need a Ute basically
[Updated on: Thu, 20 May 2004 02:49]
Classique71
Colac, Victoria
Re: Recomendations on Toyota Ute for a 1J Thu, 20 May 2004 03:05 Go to previous messageGo to next message
1J would be the go in a 2wd ute ..
I think it would be a very very sweet converion outside of making it a strip woarrior with the motor from your ta22 ..
Auto would be easierr to as most motors seem to be sourced with an auto ..
I cant see it being impossible seeing theres a heap of space under there ..
Go for it jamie ! 2WD 2jz/1jz auto hilux towmobile! !!
Skip
Re: Recomendations on Toyota Ute for a 1J Thu, 20 May 2004 04:43 Go to previous messageGo to next message
slylux has a 1JZ in a third generation type hilux i.e. after 1989 i think. Im pretty sure he had to convert it to single turbo because of clearance issues.
Other than a hliux what about those early Crown utes, they are cool.
Re: Recomendations on Toyota Ute for a 1J Thu, 20 May 2004 11:11 Go to previous messageGo to next message
stilux, that's him.
sorry bout my crassness last night man - not your fault, I was just in a really shitty mood.
there are 3 sump types for the 1jz, and you'll have to find out which one will suit a hilux best (almost certainly a front-sump type... the rarest Smile)
Mr DOHC
Re: Recomendations on Toyota Ute for a 1J Thu, 20 May 2004 11:19 Go to previous messageGo to next message
my mate is doing a 1JZ hilux convo right now, he's putting a JZZ30 manual in there, cant remember the modle but its the old RN series of early 80's, the really small ones, got 18's too Very Happy
i'll find out how he's going
1UZ FTE
Re: Recomendations on Toyota Ute for a 1J Fri, 21 May 2004 02:31 Go to previous messageGo to next message
Hmmm Crown Ute i didn't even think of this ,.....maybe i look into this some more ,..mind you they are prob getting hard to locate
Draven no prob mate, I didn't think your comment was that bad just a tad negative and everybody gets the shits once in a while
ok so Stylux or is it Stilux he should be able to help me with some advice ,....i will do a search for his posts
DOHC,.. that would be great if you are speaking to your mate to ask him if it is a realtivley easy fit,...anychance of grabing a picy or 2 for us
j
rob_RA40
c'town, NSW
Re: Recomendations on Toyota Ute for a 1J Fri, 21 May 2004 03:15 Go to previous messageGo to next message
there is a 50 series crown ute for sale in trading post something like $1500
its the 4cyl model tho.
and with any crown there will be steering box clearance issue.
lumpy
Adelaide, SA
Re: Recomendations on Toyota Ute for a 1J Fri, 21 May 2004 03:51 Go to previous messageGo to next message
It's slylux. PM me if you need his email address - I bought some bits of him a while ago.
Caelum
1JZLUX
Brisbane [South]
Re: Recomendations on Toyota Ute for a 1J Tue, 06 July 2004 10:50 Go to previous messageGo to next message
I have a 1993 (3rd gen.) Hilux 2x4 with a 1JZ Manual. It is out of a JZA70 Supra. If you have any question I'll do my best to help. It is a great conversion.
TheStitt
Membership Secretary
Re: Recomendations on Toyota Ute for a 1J Wed, 07 July 2004 01:54 Go to previous messageGo to next message
If you guys think that my Crown Wagon is rare try and fing a ute. If you do find one jamie that you don't want I'll take it.
If you do go with a crown you'll need to get the single turbo 1J or do a single turbo conversion as there are clearance issue's with the steering box.
If you got a Stout the 1G fits in Rod measured it. That would make one tuff truck.
Bugman
Re: Recomendations on Toyota Ute for a 1J Wed, 07 July 2004 03:07 Go to previous messageGo to next message
I was very interested in buying rods old stout for the 1g.. but alas i didnt have the funds on hand at the time
ChuckLandwehr
Re: Recomendations on Toyota Ute for a 1J Sat, 24 July 2004 08:23 Go to previous message
Hey THESTITT, My brother in law just gave me a call, said there was an RS46 Crown Ute 4 sale in Victorian Trading Post. Check it out at WWW.
regards Chuck.
Previous Topic:redtop tvis - redtop nontvis compatability
Next Topic:ae92 fuel filter help!
Current Time: Wed Nov 18 18:06:53 UTC 2026
Total time taken to generate the page: 0.005918025970459 seconds
