Toymods » Tech & Conversions » 4AGE Blowing Smoke + Chewing Oil
Necros
4AGE Blowing Smoke + Chewing Oil Wed, 19 May 2004 12:16 Go to next message
Hey Ppls,
My 4age is blowing smoke at startup (valve stem seals), it also blows the same bluish colored smoken when revving it up.
3000km after an oil change there was no oil (i.e. right on the tip of the dipstick) left.
And the engine stutters/pops under load (and when reving it too but not so bad) if its been idling for a little while.
Any ideas?
Re: 4AGE Blowing Smoke + Chewing Oil Wed, 19 May 2004 12:25 Go to previous messageGo to next message
blue smoke on revs/load would suggest rings on way out
... loosing >1 litre of oil after 3k confirms this
the popping/backfiring under load is probably plugs or leads 0- suggest checking to confirm (probably gunked up with oil or simply old+tired).
rebuild or at least refresh+rings time Wink
mick
toowoomba qld
Re: 4AGE Blowing Smoke + Chewing Oil Wed, 19 May 2004 12:28 Go to previous messageGo to next message
hmm the blue smoke should be fixed by replacing the valve steam seals it should stop consuming so much oil if theres nothing else wrong(hope not) as for the the motor poping and stuttering underload it may need a tune it sounds like it maybe starving for fuel by what you have said. check that theres no blockages at the fuel pump, filter, lines etc
thekemist
melbourne,australia
Re: 4AGE Blowing Smoke + Chewing Oil Thu, 20 May 2004 03:54 Go to previous messageGo to next message
i think uve got the same prob as me
im trying to work out what it is aswell
i notice the smoke from my rear view
did u see my post with the video is your anywhere near as bad as that
if u work out what it is could u post your solution here
is it the 100kw motor by the way
Necros
Re: 4AGE Blowing Smoke + Chewing Oil Thu, 20 May 2004 04:22 Go to previous message
Hey Dude,
Ive spoken to my mechanic and he also thinks its the rings... And a compression check has not garuntee of proving it as the compression rings could be fine...
Im buying a second block and rebuilding it. Nothing special just replacing the rings, bearings, giving it a clean and machining where required... Might have the comp bumped up a wee bit too...
So it looks like a rebuild of some sort for the both of us...
And those vids look nasty! Mines nowhere near that bad, but a VN SS gave me a run for my money so tis time to get my power back Smile
Previous Topic:AE86 Wiring help.
Next Topic:engine painting 3sge
Current Time: Wed Oct 28 05:44:34 UTC 2026
Total time taken to generate the page: 0.029982805252075 seconds
