Toymods » Tech & Conversions » 18r Gearbox
Shaun
Nelson NZ
18r Gearbox Thu, 20 May 2004 00:31 Go to next message
I have a 1979 rn41 toyota hilux that came with an 18r engine. I am now fitting a 18rgeu engine and have dumped the old 4spd coloum shift box. What im wondering is there a box that wil bolt up to the 18rgeu using same gearbox mounts. The only modification would be making it floor change. if yes is it a straight swap or will i have to change things up eg mounts drive shaft etc
Any help will be great
Shaun
Re: 18r Gearbox Thu, 20 May 2004 01:32 Go to previous messageGo to next message
The W50 (steel-case Celica 5 speed) will bolt up to your 18R-GEU, but I can't tell you if you'll need a different driveshaft or crossmember. What was the old box?
Shaun
Nelson NZ
Re: 18r Gearbox Thu, 20 May 2004 03:34 Go to previous messageGo to next message
IT ORIGINALY HAD AN L50 GEARBOX DOES THAT HELP AT ALL
ra23celica
Re: 18r Gearbox Thu, 20 May 2004 07:32 Go to previous message
My guess here is that the L50 and W50 are very similar and the the L refer's to a column shift mechanism. However, given that and the fact that gearbox crossmembers and tailshafts can differ, the only way for you to be sure is to measure up all the critical dimensions on your L50 and they go have a good long look at a W50.
Mitch.
Previous Topic:Steering rack boot replacement AE92 -quick one
Next Topic:Engineering Certs Differ between QLD, MELB and NSW
Current Time: Fri Oct 30 07:54:19 UTC 2026
Total time taken to generate the page: 0.0050680637359619 seconds
