Toymods » Tech & Conversions » What to make turbo header Collector out of?
adavy84
Perth, WA
What to make turbo header Collector out of? Thu, 20 May 2004 02:40 Go to next message
What metal for Collector?
OK i was going to make it out of mild steet around 10mm but was reading on the net and they say not to make it out of mild steel. but what do i make it out of??
anyone know of a place in Perth that has it?
MR. 2
Parramatta
Re: What to make turbo header Collector out of? Thu, 20 May 2004 02:57 Go to previous messageGo to next message
mild steel isnt all the best with alot of heat, i would be trying something like stanless if u can get your hands on it.
I would be making the complete manifold out of stanless also, for the simple reasons that an exhaust shop will give you 1 - 3 years warrenty on mild steel and 10 years on stanless... that has be saying something.
[Updated on: Thu, 20 May 2004 02:59]
Grega
melbourne.victoria.austra...
Re: What to make turbo header Collector out of? Thu, 20 May 2004 05:20 Go to previous messageGo to next message
stainless would be good. supposedly a good metal to make turb manifolds from.
mild steel would be ok - as long as its thick walled stuff.
fatmr2
Re: What to make turbo header Collector out of? Thu, 20 May 2004 06:45 Go to previous messageGo to next message
Steam pipe is the strongest thing you can use to make the collector. Plumbing supply shops should carry it and it isnt expensive. Albeit it is hard to work with.
Stainless is good also but you need the thicker stuff. Make sure whoever does it does it properly as i have heard a lot of people having problems with stainless ones cracking. The weight of the turbo hanging on it is a factor as well.
adavy84
Perth, WA
Re: What to make turbo header Collector out of? Thu, 20 May 2004 07:20 Go to previous messageGo to next message
I am making it myself
i have the flange made up and the steam pipe bends are all done i just have to do the collector part.
what if i used 10mm mild steel for the collector and got the lot coated in HPC coating (does anyone know how much that would cost)??
thanks all
YelloRolla
On your mum!
Re: What to make turbo header Collector out of? Thu, 20 May 2004 08:49 Go to previous messageGo to next message
If you have made the bends and such out of steam pipe, then the collector becomes a given - steam pipe! Really at 10mm you won't be making a collector (it will be a heater box) with 4 pipes firing into it.
IMO - you do not weld up the pipes and bends prior to forming the collector. I make the collector priority #1 when making a manifold. Cut the collector pipes out of straight steam pipe at the angle you desire/or is practical for your collector, number them, and then make each one fit into it's own quadrant of the turbo flange. It is a lot of work (which is why I do it first).
Alternatively - use a concentric reducer (available from the same place where you get bends) cut it down to desired size and weld pipes in - I do not recommend this method of manuacture.
Skip
Re: What to make turbo header Collector out of? Thu, 20 May 2004 08:56 Go to previous messageGo to next message
Coating on the outside with HPC will only trap heat into it, making it hotter, wont help the metal. But personally i think 10mm mild steel is heaps big enough, make sure you get the flange faced when you are finished!
YelloRolla
On your mum!
Re: What to make turbo header Collector out of? Thu, 20 May 2004 09:00 Go to previous message
Coating the manifold should prevent the material from fretting on every cool down cycle - note 304 stainless will fret as well. 316 will not.
Fretting = the surface oxidising and coming off in a very fine layer. It does this time and again until there is no metal left.
Manifold should be coated internally and externally - ceramic is best.
[Updated on: Thu, 20 May 2004 09:01]
Previous Topic:Which BOV is the best
Next Topic:vacum lines on 7mgte
Current Time: Thu Nov 19 04:43:17 UTC 2026
Total time taken to generate the page: 0.0040490627288818 seconds
