Toymods » Tech & Conversions » Making adjustable strut tops...
wilbo666
Making adjustable strut tops... Thu, 20 May 2004 12:17 Go to next message
Thinking about making a set of adjustable camber only strut tops. Who thinks this is a shit idea (why?)?
I have access to a Mill and Lathe so the machining is not a problem.
For my design (i'll get around to drawing it up in CAD soonish) I was thinking a spherical bearing, mounted in a lathed piece of polyurethane (to have some absorption/avoid metal on metal), sand witched within aluminum (as the part that adjusts to give the camber. And a 8mm thick or so (haven't sourced sizing yet) piece if Aluminum for the top part (would this be better made out of mild steel?).
A few questions...
1). Can anyone recommend a good bearing shop in Brisbane for the spherical bearing, and about how much they are worth. Also what type of spherical bearing is recommended (I hear the Teflon lined ones are the best, why is that?).
2). Can anyone recommend a good source for the polyurethane (in Brisbane pref) stock to lathe up for the bearing seats?
(the yellow pages has many stores for the above listed, just thought I'd ask for personal reconmendations first tho Smile )
_555_
SOR, Perth
Re: Making adjustable strut tops... Thu, 20 May 2004 12:38 Go to previous messageGo to next message
here is a link to oldcorollas site were he talks about his own home made adjustable strut tops. hope it helps
http://t-rex.materials.unsw.edu.au/~sford/struttop 1.html
Re: Making adjustable strut tops... Thu, 20 May 2004 12:51 Go to previous messageGo to next message
LOL, thanks for the link Very Happy saves me finding it..
i basically used a turst bearing below and above the plate (2x 5mm random aluminium sheet). the spring top is squished between the shock rod and the strut top and the top nut.
basically, it does work.
it is not ideal as if the nut is too tight, it can actualyl stiffen the steering up.
the ally plates are starting to bend.. after 4 or 5 years of service (or is it 6??)
i also had to grind off some of the shock rod to allow the spring seat to mount further down, since the total thickness of the bearings was greater than stock.
i think a good design would be...
spring top hat free to move up and down shock rod.
thrust bearing above this (some AM ppl do this) to take the weight. thin poly bush (5-10mm?) above this to reduce harshness.
then shock rod that tightens onto the spherical bearing.
only needs to be spherical to allow for offaxis movement. self aligning ballbearing could also be used. the teflon lined cushions things a bit, as metal to metal would wear faster.
i saw an awesome bearing a while back. basically a thrust bearing, with a self aligning base (like hemispherical base). rated to something like 200 tonnes Wink was a big sucker Smile
anyway, the point is. even a shit setup will work. anything you do to better my design has to be a good thing Very Happy
oh, i'd also not really bother with making those slots to adjust the position.
a carefully shaped top plate with a few different sets of holes will suffice.. if the bearing plate mounts uder the top plate, then so easy to just swap out the top plate for major alignment changes....
wilbo666
Re: Making adjustable strut tops... Thu, 20 May 2004 13:54 Go to previous messageGo to next message
Very Happy I had seen that site in my travels, but I didn't realise that it was oldcorollas!
Fantastic Smile
Hopefully I'll get the tops out of the parts car on Saturday (as well as the radius rods to put more thread on) and be able to do some measurements and maybe wack something up in CAD...
earlyrolla
Re: Making adjustable strut tops... Fri, 21 May 2004 11:16 Go to previous messageGo to next message
You are probably better off with 8mm steel (as Stewart said, the aluminium will bend after extended use).
Have a look at this first:
http://www.oakos.com/Merchant2/merchant.mv?Screen= PROD&Product_Code=NOL44003-MRT
As it makes the following explanation easier.
Here is my version of the above.
The top and bottom sandwich plates are laser-cut (cheapish and very, very neat) from 6-8mm aluminium and the centre plate (the one with the bearing in) is cut from say 6-8mm steel.
The bearing housing (see below) is turned up on a lathe then welded onto the underside of the laser cut centre steel plate.
The centre steel plate is a 'Y' shape with a hole in the middle where the top of the strut will poke through.
The urethane bush housing needs a circlip groove cut in it near one end while on the lathe. The groove will hold the circlip (with a suitable washer) that inturn holds in the urethane bush surrounding the appropriate bearing. Make sure you weld the bearing housing on with the circlip groove at the correct end Smile
For the bearing housing it would probably be easier to start with a piece of thick walled steel pipe of the appropriate size to make it easier.
All make some sense?
[Updated on: Fri, 21 May 2004 11:25]
wilbo666
Re: Making adjustable strut tops... Fri, 28 May 2004 03:49 Go to previous message
Hmm well it does appear that it isn't as easy as I had first suspected!
The total height from bearing bottom (where the spring seat sits) to where the strut top is designed to mount to the chassis is only about 22mm. Ideally I would like to mount the bearing on the top of the main plate, but in that case I would prbly take up 60mm at least! I really need to get some pics up so I can explain myself better I think...
Anyway atm it looks like I will have to make the base out of something 22mm thick, machine a larger groove (in the direction of adjustment) in the main plate for the bearing, and secure it in place with another piece of metal from the top. This should allow the bearing to be mounted only 8mm or so above where it is located in the stock setup, allowing me enough thread to still secure the nut above the bearing. I will use a small tube of metal as a spacer to located the spring seat in the stock location (and not foul on the material that is used to hold the bearing in on the bottom).
I'll try and get some diagrams of the planned setup soon Confused lol
Previous Topic:mr2 engine mount
Next Topic:Different types Tyre?
Current Time: Wed Oct 21 02:57:19 UTC 2026
Total time taken to generate the page: 0.0051660537719727 seconds
