Toymods » General Car Talk » upgrading brake booster for ae86
joyride
fairfield NSW
upgrading brake booster for ae86 Thu, 20 May 2004 16:28 Go to next message
hey guys, i did a quick search using "upgrading brake booster" but it didnt come up with anything so...
what would you use if you wanted to upgrade the brake booster AFTER you did a front brake swap ?? eg FC3S swap.
i went to a brake shop and they quoted me 180 bucks to bore out(?) the existing brake booster/msater cylinder (cant remember what he said and im not good with techincal side of brakes).
would it be easier just to swap one from a different car? someone told me once that a RAV4 is good to use?
LiL_MiC
Melb
Re: upgrading brake booster for ae86 Fri, 21 May 2004 04:09 Go to previous messageGo to next message
i thought i saw someone get one out of a sigma or something? Pretty sure it was from this forum too.. I could be wrong
improvedae86
Re: upgrading brake booster for ae86 Fri, 21 May 2004 04:42 Go to previous messageGo to next message
Starion 1" bore size ?, are we taking master , or booster ?
joyride
fairfield NSW
Re: upgrading brake booster for ae86 Fri, 21 May 2004 06:15 Go to previous messageGo to next message
ok, the brake shop guy said that (i think) the master cylinder can be bored out to accomodate my needs. is this a good idea? i never told him what kind of swap i was doing.
ive swapped on the FC3S brakes/calipers on my ae86, should i bore out or swap the master cylinder? or should i swap the booster aswell?
http://static.howstuffworks.com/gif/brake-layout-all.jpg
improvedae86
Re: upgrading brake booster for ae86 Fri, 21 May 2004 06:43 Go to previous messageGo to next message
So it the master , theres lots of chooses for this with that upgrade i would do a search and pm people who have this conversion , the last car i drove with this conversion had the stock master and the pedal was almost on the floor , so they must need more fluid displacement for the bigger pistons in the caliper .
EVOSTi
cambo
      no
Re: upgrading brake booster for ae86 Sat, 22 May 2004 10:17 Go to previous messageGo to next message
this should be in the tech section but anyway...
theres no need to upgrade the booster unless it is stuffed, your wanting an upgraded master cylinder. you can bore it out but this is not ideal as it makes the material thinner making it more prone to 'balooning' this is unlikely but not worth the risk when there is a simple solution.
a STARION master cylinder is what i use, its the easiest option. the recess to the piston is the same as the sprinters so the master cylinder itself bolts straight on. there are two pipes that connect to it. the rear pipe matches up almost perfectly while the front one will have to be fabricated. this i did myself with some copper brake line and a flaring kit which you wont have, so a brake shop will make you up a new front pipe probably for around $15. this modification will make your pedal much firmer and more responsive. Smile
joyride
fairfield NSW
Re: upgrading brake booster for ae86 Sun, 23 May 2004 21:21 Go to previous messageGo to next message
thanks for the tip EVOSTi, thats what i needed to hear.
is there any particular year (1980? 1986?) that i'll need? i dont know much than starions other then they are old cars too lol.
[Updated on: Sun, 23 May 2004 21:23]
EVOSTi
cambo
      no
Re: upgrading brake booster for ae86 Mon, 24 May 2004 09:25 Go to previous messageGo to next message
it doesnt matter what year, they are all the same. your prob looking at anywhere between $100 - $180. i think last time i got one was around $150 from the mitsubishi wreckers in greenacre.
Youngy
Eskilstuna, Sweden
Re: upgrading brake booster for ae86 Wed, 26 May 2004 02:20 Go to previous messageGo to next message
What is the bore size of the Starion master cylinder?
joyride
fairfield NSW
Re: upgrading brake booster for ae86 Wed, 26 May 2004 03:48 Go to previous messageGo to next message
i did a bit of looking, i think its 7/8" or 15/16"....???
AE86slut
Baulko Hillo
Re: upgrading brake booster for ae86 Wed, 26 May 2004 03:54 Go to previous messageGo to next message
The guy I got my car off (a good mate) had the FC brake conversion I have on my car now on his old Sprinter with the stock booster and master cylinder and it pulled up bloody well.
EVOSTi
cambo
      no
Re: upgrading brake booster for ae86 Wed, 26 May 2004 12:09 Go to previous messageGo to next message
i think stock sprinter is 7/8 and the starion one is 15/16, something like that i cant be bothered going out to look Razz
joyride
fairfield NSW
Re: upgrading brake booster for ae86 Wed, 26 May 2004 20:56 Go to previous message
EVOSTi wrote on Wed, 26 May 2004 22:09
lol thats cool, i'd be too lazy aswell Surprised
Previous Topic:Concept of my Corolla ---> opinions wanted!
Next Topic:Inspiration Pics.
Current Time: Sun Oct 25 13:51:12 UTC 2026
Total time taken to generate the page: 0.010721921920776 seconds
