Toymods » Tech & Conversions » Going from panel filter to pod
gen_gt4
Going from panel filter to pod Fri, 21 May 2004 04:11 Go to next message
heys,
i recently bought a celica gt4 (88model) and after fiting a boost guage i realised was running 10psi. at this point, there were no signs of a boost controller, and all it had was a 2.5" or bigger exhaust frm where the cat is supposed to be (its running no cat and was licensed like that....with snow tyres too may i add.. ).
i then purchased a hks pod filter (second hand) and now is running 2-3psi less than b4 the pod was fitted. when i was fitting the pod filter (got it done at an exhaust shop) i realised that i had an apexi filter panel inside the stock airbox.
my question is, aint pod filters suppose to gain power, not lose?? and would a clean/new filter element on the hks pod give back his 2-3psi?
sorry for long post
thx
alvin
Re: Going from panel filter to pod Fri, 21 May 2004 04:26 Go to previous messageGo to next message
Well the lampshade filter you bought is presumably grubby as all hell...
Re: Going from panel filter to pod Fri, 21 May 2004 04:30 Go to previous messageGo to next message
Pod filters do not necessarily offer a performance increase over a late-model factory airbox and filter. In fact it's quite common to lose performance when installing a pod filter. This is because people insist on fitting them even when there's absolutely nothing wrong with the factory setup; they just do it because it's the "done thing".
So my advice is to throw the shitty pod filter in the bin, and re-install the airbox which was carefully designed by Toyota's engineers.
gen_gt4
Re: Going from panel filter to pod Fri, 21 May 2004 05:18 Go to previous messageGo to next message
will replacing the hks filter element help? and does anyone noe will the simota hks lookalike filter element fit?
SeptemberSquallIndustries
Re: Going from panel filter to pod Fri, 21 May 2004 06:57 Go to previous message
Norbie wrote on Fri, 21 May 2004 14:30
Previous Topic:4age fuel line help pls
Next Topic:Anyone done a 1ggte conversion?
Current Time: Tue Oct 27 11:41:59 UTC 2026
Total time taken to generate the page: 0.056559085845947 seconds
