Toymods » Tech & Conversions » AE82 oil cooler on a 20V?
the dayo
AE82 oil cooler on a 20V? Fri, 21 May 2004 04:22 Go to next message
bought a complete oil cooler kit off an AE82 and was wondering how to install it on a 20V, i'm asking as my car is at the exhaust shop and connot visualise it at the moment, i'm not to sure where the the return line goes back to the engine.
Re: AE82 oil cooler on a 20V? Fri, 21 May 2004 04:59 Go to previous messageGo to next message
Return line goes back into the side of the sump...
Alainve
Newcastle NSW
Re: AE82 oil cooler on a 20V? Fri, 21 May 2004 15:27 Go to previous messageGo to next message
yep side of the sump. just use a banjo fitting with a nut tacked on the inside of the sump.
if you dont have any banjo fitting go to your local mitsubishi wrecker and see if you can get the rubber hoses either side of the fuel filter from a TM magna (early square shitty looking ones) make sure its an EFI one tho. if you pull it off yourself it should be free or close to nothing anyway. just cut the hose off and use the barb with new hose. the fittings angle the line out at 45 degrees to the bolt so fit niceley and look stockin any aplication.
if you have the banjo fitting ignore all that incessant rambling Razz exept tacking the nut on the inside Very Happy
the dayo
Re: AE82 oil cooler on a 20V? Sat, 22 May 2004 07:07 Go to previous messageGo to next message
does this mean drilling a hole in the sump? and welding a nut to it?
AE86slut
Baulko Hillo
Re: AE82 oil cooler on a 20V? Sat, 22 May 2004 09:28 Go to previous messageGo to next message
Nope, just ordinary thumb tacks.
(Sorry, couldn't help myself)
Alainve
Newcastle NSW
Re: AE82 oil cooler on a 20V? Sun, 23 May 2004 02:09 Go to previous messageGo to next message
its a sump off job and make sure you clean the oil out well. dont want to start a fire Evil or Very Mad
towe_001
Somewhere on a dirt bowl ...
Re: AE82 oil cooler on a 20V? Thu, 12 August 2004 09:24 Go to previous messageGo to next message
If your none to fussed on using thumb tacks or welding (glue? Laughing)
How about using the sump from the AE82 Twinky? Or wont it fit the 20v?
Leighp
NY
Re: AE82 oil cooler on a 20V? Fri, 13 August 2004 01:12 Go to previous messageGo to next message
ae 82 and 92 sumps dp not go on the 101 (the 101 sump has a kink in it that the others do not have) I know all this as i just put my oil cooler back on my 20 v and it is so much better now. I put a fitting in after drilling a small hole, then hitting it with a taper punch, then i added the same size thread and screwed in a flare fitting that will be sweet in my return hose.
Hooked up all the rest "and bobs your uncle (or your aunt what ever way he swings)" and now the 20v is screaming again.
AE86slut
Baulko Hillo
Re: AE82 oil cooler on a 20V? Fri, 13 August 2004 07:47 Go to previous messageGo to next message
Leighp, I'm curious as to what the major differences you notice are. I am putting one of these on my 20V asap.
Flogbag
Sydney (Campbelltown...!)
Re: AE82 oil cooler on a 20V? Sat, 14 August 2004 03:03 Go to previous messageGo to next message
where do u put the feed to the cooler
are the sandwhich plates between the block n the oil filter interchangeable with ae82 ones?
if so could u use the ae82 one on a 20v and put the feed to that and the return to your sump?
Leighp - where did u hook up the feed from?
[Updated on: Sat, 14 August 2004 03:03]
Hunty
Re: AE82 oil cooler on a 20V? Sat, 14 August 2004 06:57 Go to previous messageGo to next message
did only the 86kw 4ags have the oil cooler?? ive got a ae92 100kw 4ag in my ae82 and it didnt have an oil cooler or any lines on the sump?? is it worth the hassle of fitting one?
Leighp
NY
Re: AE82 oil cooler on a 20V? Mon, 16 August 2004 04:25 Go to previous messageGo to next message
first difference was that i could notice that the oil was not shearing as much (shearing being where it burns and blows out as smelly smoke). Second difference is that i can run a thinner oil and the car performs better (due to less heat and shearing again).
In order to install the cooler i ripped off all the fittings around the filter, (there is a 2 part piece that attaches to the filter then the block, that is held on by 4 bolts, undo them then with a 27mm socket take off the bolt holding what ever that other piece is and inturn that piece will come off also. Then put the 4age feeder straight on, use the special double threaded bolt and attach a filter. then fit lines appropiately. as for the sump there are many ways about it, I put a fitting in after drilling a small hole, then hitting it with a taper punch, then i added the same size thread and screwed in a flare fitting that will be sweet in my return hose.
Others use a double bolt, what ever suits you. There it is
Sorry about the lack of knowledge of the part names, but i tried....all i know is that the car runs alot better
hunty i have a sump that i can sell to you that should bolt straight on........
Hunty
Re: AE82 oil cooler on a 20V? Mon, 16 August 2004 04:31 Go to previous messageGo to next message
ahh but i have no cooler and lines.... cheers anyway leigh. Hmm wots the going rate for an oil cooler?? does sound like it may be worth it.
AE86slut
Baulko Hillo
Re: AE82 oil cooler on a 20V? Mon, 16 August 2004 07:25 Go to previous message
leighp,
Did you notice any difference as far as the VVT is concerned?
Jeremy.
Previous Topic:AE86 front springs, what fits?
Next Topic:3sgte with W55?
Current Time: Fri Nov 20 21:02:02 UTC 2026
Total time taken to generate the page: 0.31273102760315 seconds
