Toymods » Tech & Conversions » MA61 struts into an RT142
chubbylover53
MA61 struts into an RT142 Fri, 21 May 2004 06:20 Go to next message
Is there any similarities between the front end of an old supra ( eg MA61) and an RT142. i want to know if the 25mm front sway bar from a supra would fit into a corona. Also will the front struts out of a ma61 fit an RT142.
cheers.
Bugman
Re: MA61 struts into an RT142 Sat, 22 May 2004 04:55 Go to previous messageGo to next message
struts will but use ra65 ones you'll find em more and will be cheaper and are the same things.
Re: MA61 struts into an RT142 Sat, 22 May 2004 07:15 Go to previous messageGo to next message
No they're not.
wilbo666
Re: MA61 struts into an RT142 Sat, 22 May 2004 15:19 Go to previous messageGo to next message
Yeah the MA61 has a different top spring seat and spring compared to RA65, also i think they might have more of a king pin angle (more -ve camber) but I'm not 100% sure on that, jemery/ed (others?)?
Bugman
Re: MA61 struts into an RT142 Sun, 23 May 2004 04:02 Go to previous messageGo to next message
ok but moral is use ra65 ones?
Re: MA61 struts into an RT142 Sun, 23 May 2004 06:04 Go to previous messageGo to next message
Yes.
gold28
Madrid - Spain
Re: MA61 struts into an RT142 Mon, 24 May 2004 00:41 Go to previous messageGo to next message
And something I found out the weekend before last, the MA61 lower control arm is slightly longer than the RA60 one. So for all thoes RA60 drivers that want an extra 0.5 degrees negative camber you know where to go Very Happy
SRacin
Christchurch, New Zealand
Re: MA61 struts into an RT142 Mon, 24 May 2004 03:43 Go to previous messageGo to next message
deosnt the rt142 have the struts that people use to do the pug/hilux upgrade in old celicas? hence just do that upgrade?
Logan
Bugman
Re: MA61 struts into an RT142 Mon, 24 May 2004 05:14 Go to previous messageGo to next message
no celica people use the rt132.
some people put ra65 stuff into the earlier celicas but this stuff up the geomatry a bit, but it is right for the rt142(whcih is built same era, it's actually quite the same car. well the import ones are)
chubbylover53
Re: MA61 struts into an RT142 Mon, 24 May 2004 08:00 Go to previous messageGo to next message
Does that mean that if i use the lower control arm from an Ra60 with the RA65 struts it will give me more neg camber because that is the whole reason i am changing the struts, i need heaps more neg camber for the race track.
thanxx for the help
[Updated on: Tue, 25 May 2004 09:44]
Re: MA61 struts into an RT142 Mon, 24 May 2004 08:03 Go to previous messageGo to next message
The RA60/65 struts should be the same. All things equal, the RA60/65 struts give 2 degrees extra camber over the MA61 by themselves, and coupled with the MA61 control arms this should be even more.
wilbo666
Re: MA61 struts into an RT142 Mon, 24 May 2004 08:49 Go to previous messageGo to next message
jcmf, where do SA63 struts sit in the scope of things? The same kingpin as MA61 or RA60/65? Smile (guessing the same as RA60/65?)
Re: MA61 struts into an RT142 Mon, 24 May 2004 08:50 Go to previous messageGo to next message
I'd be speculating, but I don't think Toyota would've re-engineered new struts for them.
gold28
Madrid - Spain
Re: MA61 struts into an RT142 Mon, 24 May 2004 12:04 Go to previous messageGo to next message
Yeah it's the supra control arms you want
chubbylover53
Re: MA61 struts into an RT142 Tue, 25 May 2004 09:52 Go to previous messageGo to next message
would i need to use an RA65 steering rack with the new struts.
wilbo666
Re: MA61 struts into an RT142 Tue, 25 May 2004 10:03 Go to previous message
I believe that they should bolt to the existing steering arms.
If that is the case then the existing steering arms and rack will be retained.
Previous Topic:carb experts in here please
Next Topic:which gearbox
Current Time: Sun Oct 18 21:01:05 UTC 2026
Total time taken to generate the page: 0.006756067276001 seconds
