Toymods » Tech & Conversions » Connecting up 100kw intake to GZE?? PICS INC
adavy84
Perth, WA
Connecting up 100kw intake to GZE?? PICS INC Fri, 21 May 2004 07:34 Go to next message
OK i have pulled off the gze intake and bolted on a small port 100kw intake as im going TURBO.
Now im using the origianal Loom from the halfcut and GZE computer (MAP) and ther are a few devices that i dont know if i need them OR where they go.
i have take some pictures of them and can someone help me out to where they get connected too. (or if i need them)
One other thing is where would i find the fuel pump relay?
its all taken from a ae92 4agze Map halfcut if thats any help
Thanks.
http://www.picturetrail.com/gallery/view?p=999& ;gid=4346689&uid=2225281
kingmick
Banned by his request
moved to tamworth
Re: Connecting up 100kw intake to GZE?? PICS INC Fri, 21 May 2004 10:12 Go to previous messageGo to next message
relay is in the bottom of the middle console i.e were the stereo and aircon or air controls are. if you get someone to turn the ignition on while you sit in passange seat with ear close to middle console you will hear it click when they turn the ignition and the pump primes.
mick
p.s make sure you use a blow off valve . and you will have a ruff idle.
adavy84
Perth, WA
Re: Connecting up 100kw intake to GZE?? PICS INC Fri, 21 May 2004 12:41 Go to previous messageGo to next message
Why do i need a BOV?
how would one effect the idel?
adavy84
Perth, WA
Re: Connecting up 100kw intake to GZE?? PICS INC Fri, 21 May 2004 13:34 Go to previous messageGo to next message
IF anyone has the 4age small port vacuum diagram, would be a good help.
[Updated on: Fri, 21 May 2004 13:37]
takai
Re: Connecting up 100kw intake to GZE?? PICS INC Fri, 21 May 2004 13:54 Go to previous messageGo to next message
Actually the relay which you can hear click next to the ECU is the general systems control relay, cant remember the specific name at,.
The AE92 GZEs actually have a seperate fuel pump relay in the engine bay. Just forward of the passenger location, above the aircon piping. Thats where mine sits, and sat in the frontcut. Then again im not using it, its there for decoration.
As for the BOV, its so you dont get compressor feedback on gear changes.
adavy84
Perth, WA
Re: Connecting up 100kw intake to GZE?? PICS INC Tue, 25 May 2004 00:29 Go to previous messageGo to next message
So does anyone know where i would find the wire to connect to the fuel pump? is it in the loom that goes down the middle of the car (to the rear) ??????
takai
Re: Connecting up 100kw intake to GZE?? PICS INC Tue, 25 May 2004 01:56 Go to previous messageGo to next message
On my SX it was a blue w black stripe going down the passenger side.
adavy84
Perth, WA
Re: Connecting up 100kw intake to GZE?? PICS INC Tue, 25 May 2004 02:16 Go to previous messageGo to next message
Do u know if the fuel gauge sender wires where also in the passenger side loom?
adavy84
Perth, WA
Re: Connecting up 100kw intake to GZE?? PICS INC Tue, 25 May 2004 12:05 Go to previous messageGo to next message
ok i have worked out the fuel pump but still having troble with the Vacume components.. does anyone have close up pics of ther 4agte with stock computer?? or tell me what i need and dont.
thanks guys
adavy84
Perth, WA
Re: Connecting up 100kw intake to GZE?? PICS INC Wed, 26 May 2004 08:06 Go to previous messageGo to next message
With the fuel pump wire when should i see the 12volts???
ATM with IG off it shows 3volts and goes to 6volts when i put the IG ON?? Confused
Does anyone know what the colour of "LB" is from Toyota wiring diagram?
[Updated on: Wed, 26 May 2004 08:09]
Rod83
Re: Connecting up 100kw intake to GZE?? PICS INC Wed, 26 May 2004 08:34 Go to previous message
That's blue-black.
Previous Topic:Oil gauge gone crazy
Next Topic:TRD Quick Shift Kits
Current Time: Thu Nov 19 15:31:45 UTC 2026
Total time taken to generate the page: 0.016345977783203 seconds
