Toymods » Tech & Conversions » AE86 r32/nissan GTR/GTST front brake conversion
45aken
NSW.south coast.Drifting
AE86 r32/nissan GTR/GTST front brake conversion Fri, 21 May 2004 09:10 Go to next message
ive heard about a few ae86's with r32 gtr front brake conversions, anyone else heard of this conversion? what about with just gtst brakes (aka much cheaper)?
FKN16V
NSW, East Coast
Re: AE86 r32/nissan GTR/GTST front brake conversion Fri, 21 May 2004 12:35 Go to previous messageGo to next message
I heard this too, i do think it was talked about a while ago, did you search, what did you find.
Steve
FKN16V
NSW, East Coast
Re: AE86 r32/nissan GTR/GTST front brake conversion Fri, 21 May 2004 12:46 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=23189&rid=3118&S=b0ef37332e9e0dd37602ce1 6eb69d939&pl_view=&start=0#msg_194000
Its a start?
gabe
Re: AE86 r32/nissan GTR/GTST front brake conversion Fri, 21 May 2004 14:52 Go to previous messageGo to next message
Just completed this very conversion.
Although I did it a little different to others.
I used the R32 calipers and matching rotors. This gives you a new PCD of 5 x 114.3
I made custom hubs and caliper brackets. The hubs bolt to the standard sprinter strut. Original wheel bearings and seal can be used.
There are cheaper ways of doing it, do a search for this info, but none let you retain the sprinter strut and bearings.
You could also use s13 struts as a base and go from there but i think 5 studs is the go just due to the mag selection.
Gabe
Re: AE86 r32/nissan GTR/GTST front brake conversion Sat, 22 May 2004 07:00 Go to previous messageGo to next message
Yeah, I've heard of it, oh, wait on, I did it Very Happy
FKN16V
NSW, East Coast
Re: AE86 r32/nissan GTR/GTST front brake conversion Sat, 22 May 2004 07:11 Go to previous messageGo to next message
mrshin wrote on Sat, 22 May 2004 17:00
Mr informative.
Care to share your experience.
twinturbo86
Re: AE86 r32/nissan GTR/GTST front brake conversion Sat, 22 May 2004 23:38 Go to previous messageGo to next message
i did the gtst upgrade & the whole conversion cost me about $650
its a good idea to step up the size of the master cylinder too cause i was gettin a low pedal.
Re: AE86 r32/nissan GTR/GTST front brake conversion Sun, 23 May 2004 02:51 Go to previous messageGo to next message
Alrighty, I'm short on time now, but here's what I did in very quick words:
R33 calipers
GTR Vspec (320something MM) rotors
UZS131 Crown hubs, machined down externally, different bearings, NASCAR studs (looooong!)
Made some caliper adapter brackets, because the larger rotor needed the calipers in a different place, however if you use the 297mm rotors, you only need a small spacer, the bolt holes line up and the offset is correct. This is with RA60 struts, though!
I also adapted an MX83 master cylinder to the AE86 booster.
Total cost ~$700 including new rotors, then later $200ish more for greenstuff pads
Sorry to be so short on details, but I haven't got a heap of time right now! I'll try and take some photos though...
FKN16V
NSW, East Coast
Re: AE86 r32/nissan GTR/GTST front brake conversion Sun, 23 May 2004 04:58 Go to previous message
mrshin wrote on Sun, 23 May 2004 12:51
R33 calipers
Pics would be nice. Cheers.
Previous Topic:3SGTE internals?
Next Topic:What ohm readings for TA22 fuel level gauge?
Current Time: Thu Oct 29 07:51:00 UTC 2026
Total time taken to generate the page: 0.0060789585113525 seconds
