Toymods » Tech & Conversions » What would I need to change if I put a 7MGTE in a GA70?
Rattlehead
What would I need to change if I put a 7MGTE in a GA70? Thu, 29 August 2002 16:00 Go to next message
I'm not really sure but the things I'll get are the engine, tranny, computer and loom, AFM and the piping and intercooler.
I'm not sure if I'll get the powersteering pumps and those things...will I need to change the radiator since I think the GA70 ones are smaller???
I gotta see if it's worth the conversion now or if I should wait til mine goes kaboom since I won't be able to sell my engine (122,000ks).
Any info would be great thanks.
rob_RA40
c'town, NSW
Re: What would I need to change if I put a 7MGTE in a GA70? Thu, 29 August 2002 22:37 Go to previous messageGo to next message
if u dont manage to get the power steer pump with the 7M u can use the 1G pump its the same, and i have a feeling they mount the same as well.
if its a front cut or engine package u should be getting all of the ancillaries, but make sure u check they are all there before u buy.
when i got my front cut we noticed the air con compressor was gone so they dropped the price, problem was, that when we got it home we found the starter motor was gone as well.
good luck with the conversion
666supra
U.S.A
Re: What would I need to change if I put a 7MGTE in a GA70? Sat, 31 August 2002 00:17 Go to previous messageGo to next message
Just one question:
Why go 7m-gte when you can do the same with 1jz-gte?
Rattlehead
Re: What would I need to change if I put a 7MGTE in a GA70? Sat, 31 August 2002 07:32 Go to previous messageGo to next message
I want a 1JZ, but I found a cheap 7M thats been rebuilt and heads been serviced etc...
I dunno if I'll get it, but I want to know incase...coz the guy will only be giving me the things he doesnt need. But he said he'll give me things like powersteering, air conditioning and stuff.
Darkstar
Ebbw Vale, Qld
Re: What would I need to change if I put a 7MGTE in a GA70? Wed, 03 November 2004 22:12 Go to previous messageGo to next message
Will the 7M bolt straight in as far as engine mounts are concerned? If they do fit straight on the mounts, will there be enough space at the front and rear of the engine so as not to foul the radiator or firewall?
Same question as for a 1J from a JZA70 to a GA70, any ideas?
Re: What would I need to change if I put a 7MGTE in a GA70? Thu, 04 November 2004 01:04 Go to previous messageGo to next message
All Mk3 Supra's have the same chassis, so there will be no clearance issues. The crossmember and engine mounts were updated in 89 I think, so you need to make sure the engine you get has the right mounts to match your crossmember. The 1JZ has the later style mounts, the 1G has the early style, and the 7M has both.
Darkstar
Ebbw Vale, Qld
Re: What would I need to change if I put a 7MGTE in a GA70? Thu, 04 November 2004 05:40 Go to previous messageGo to next message
So all 1G's have the old style even the post '89 models?
I don't spose u could swap X-members from one 7M/1J/1G
wilbo666
Re: What would I need to change if I put a 7MGTE in a GA70? Thu, 04 November 2004 06:36 Go to previous messageGo to next message
Darkstar wrote on Thu, 04 November 2004 16:40
I think so.
And I believe that you can swap crossmembers Smile
lumpy
Adelaide, SA
Re: What would I need to change if I put a 7MGTE in a GA70? Thu, 04 November 2004 06:53 Go to previous messageGo to next message
Darkstar wrote on Thu, 04 November 2004 16:10
You certainly can swap crossmembers from 7m early to late to 1j etc. Also a good time to put some new bushes in the suspension whilst it's all out and easily accessible. Newer crossmembers have the round, fluid filled mounts. Older ones were square rubber bolcks with a little shock absorber bolted to the back of the engine.
Rattlehead
Re: What would I need to change if I put a 7MGTE in a GA70? Thu, 04 November 2004 10:31 Go to previous message
Since the original post - car has put on 60,000kms.
In a few weeks I'll be able to confirm is the 89+ GA70's have the newer or older x-member.
Btw - ended up getting a JZA70 manual half cut. So thankyou to all you Toymodders who have answered my annoying questions.
Previous Topic:Mk2 7mgte Project
Next Topic:gze piston pics
Current Time: Sat Nov 21 05:37:55 UTC 2026
Total time taken to generate the page: 0.0061869621276855 seconds
