Classifieds » Miscellaneous » 3T-GTE with W58, ECU, LOOM - in Adelaide
daytona
Wroclaw, Poland, Central ...
3T-GTE with W58, ECU, LOOM - in Adelaide Thu, 29 August 2002 16:26 Go to next message
Hi Guys,
I am selling a 3T-GTEU engine complete with the following:
Delco ECU, with loom, 2 Bar MAP sensor, relays, everything you need to wire it up. The chip was done by Fueltronics.
Can run upto 14.9psi of boost (limit of the MAP sensor, injectors, and turbo, as it will over rev.) on pulp.
Supra MA61 W58 Gearbox, with the good ratios, unlike the ones found in the original W55 box.
Clutch and pressure plate 5000km's old, flywheel machined when clutch was changed. Spigot bearing also changed.
Non water cooled CT20 turbo in good condition.
Selling it because I'm going overseas for another 4 years, and can't afford to have it sitting around.
Engine is in Adelaide, asking $2000.ono for the lot.
email me at daytona@poczta.fm if interested as I dont have the time to get on here that often.
Rob
[Updated on: Thu, 29 August 2002 16:33]
stevegee
Re: 3T-GTE with W58, ECU, LOOM - in Adelaide Tue, 24 September 2002 12:11 Go to previous message
I emailed you about buying this what gives?
Previous Topic:Sprinter AE86 bits and some speakers and amps..
Next Topic:18R-G electronic distributor
Current Time: Thu Oct 29 14:27:16 UTC 2026
Total time taken to generate the page: 0.086992979049683 seconds
