Toymods » Tech & Conversions » Supra (F series) RA.45 (GT) LSD 7.5 centre
Bluewire
Adelaide, South Oz
Supra (F series) RA.45 (GT) LSD 7.5 centre Sat, 22 May 2004 08:31 Go to next message
Ok can you guys help me out.... Confused
Ive got a Supra (F series) RA.45 (GT) LSD 7.5 centre on my RA40 Celica (Bluewire) and i want to fit it in to a RA28 Mustang back Celica.
http://www.classic-celica.com/albums/album09/41_G.sized.jpg
Can it be done.......
Thanks Sean...............
CLG
Perth, Western Australia
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sat, 22 May 2004 10:09 Go to previous messageGo to next message
No, all the pick up points for the control arms are in the wrong spots, and the diff is wider than the RA28 item. If you force it in there, your bushings will bind on the points, bolts, and body.
CelicaRA45
nth ringwood, Victoria
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sat, 22 May 2004 11:09 Go to previous messageGo to next message
sean try a mx23 rear end but you will still have to cut off the pickup points from the T series to put onto the Fseries
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sat, 22 May 2004 14:20 Go to previous messageGo to next message
MX13/23 diff is 1410mm across. Too wide.
CLG
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sat, 22 May 2004 15:52 Go to previous messageGo to next message
And an RA23/28 is only 1365mm!
Bluewire
Adelaide, South Oz
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sat, 22 May 2004 16:34 Go to previous messageGo to next message
So what do you think is the best LSD Disc brake unit to fit in my RA28...
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sat, 22 May 2004 23:43 Go to previous messageGo to next message
Get a Toyota Crown MS112 diff and cut it down (cheap as chips and common as dirt). Weld RA28 suspension points to it (do a comparison - it may be very similar - I don't know as I have never looked). Redrill axles and rotors to 4 stud. Put an MA61 LSD centre into it. Custom handbrake cable. This diff runs beautiful (and frightfully expensive) dual race axle bearings just like your RA45 one.
Lighter than a Hilux diff, better than a Bog Warmer limo and of equal strength to your RA45 diff. I used one in my Corona Mk2 and have converted it to ventilated discs but still using the standard (slightly modified) calipers. Should you desire, it is easy to get out to a 300mm rotor still using the internal drum handbrake. I have some pics I could email to you of the ventilated brake conversion if you choose to go down this path.
MS112 diff is 1410mm across.
[Updated on: Sat, 22 May 2004 23:51]
Allan
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sun, 23 May 2004 01:57 Go to previous messageGo to next message
gianttomato wrote on Sun, 23 May 2004 09:43
Cheaper to convert the front to 5 stud Smile
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sun, 23 May 2004 02:14 Go to previous messageGo to next message
Allan wrote on Sun, 23 May 2004 11:57
Not if you already have some very shiny expensive wheels to suit a 4 stud pattern. Smile
Allan
Re: Supra (F series) RA.45 (GT) LSD 7.5 centre Sun, 23 May 2004 07:39 Go to previous message
gianttomato wrote on Sun, 23 May 2004 12:14
But if you have bling a T series would be fine Razz
Previous Topic:Good drag tyres?
Next Topic:what series of diff on a 18rc ra40?
Current Time: Sun Oct 25 21:47:06 UTC 2026
Total time taken to generate the page: 0.0048739910125732 seconds
