Toymods » Tech & Conversions » 18RG hi lift cam clearance issues
Mr DOHC
18RG hi lift cam clearance issues Sun, 23 May 2004 07:40 Go to next message
does anyone know if hi lift {no duration changes} cams combined with bigger valves could interfere with each other.
i'm getting Ferrea valves for my car {O/S} and base-circle ground cams for my 18RG, could there be any clearance issues
YelloRolla
On your mum!
Re: 18RG hi lift cam clearance issues Sun, 23 May 2004 09:50 Go to previous messageGo to next message
This will depend on cam timing and the size of the valves. You will need to check it when you put the engine back together.
The more common clearance issue is with valves intefering with the pistons, not each other; at overlap I can't see the valves hitting each other being a problem.
Mr DOHC
Re: 18RG hi lift cam clearance issues Sun, 23 May 2004 09:59 Go to previous messageGo to next message
i have a 88250 head, and the cam grinder said that the cams were way too small for the head so i'd say he'll grind them alot, the valves are probably only gonna ba bit bigger [1mm or so}, the cam timing will be set as std
Mr DOHC
Re: 18RG hi lift cam clearance issues Sun, 23 May 2004 10:00 Go to previous message
YelloRolla wrote on Sun, 23 May 2004 19:50
my dad who lives in townsville's doing the head and i will be installing it so he cant check the clearances
Previous Topic:confused about selling TA22 unfinished Project!
Next Topic:another disk brake question
Current Time: Sun Oct 25 22:24:44 UTC 2026
Total time taken to generate the page: 0.0039598941802979 seconds
