Toymods » Tech & Conversions » Starting Problem ST-162
Skinnypoo
Tasmania
Starting Problem ST-162 Mon, 24 May 2004 03:20 Go to next message
Hi guys just having a problem when starting my car
when I turn the key and the engine starts to turn over, if the engine light on the dash goes out the car will just crank without firing and will do it for as long as u want if this happens I have to turn the ignition to off then try again. But if the engine light stays on when the car is turned over it will start without missing a beat. A guy i work with said his car does the same with his 20v 4age. Does anybody know what the problem is?
We are thinking it might be the crank angle sensor
are these expesive to replace?
Cheers Josh
RWDboy
Re: Starting Problem ST-162 Mon, 24 May 2004 07:11 Go to previous messageGo to next message
Check for an engine error code...
First you may want to check for spark though.
Does the ST162 actually have a CAS? I've never looked (always meant to) but it doesn't seem like it does.
wiso
Re: Starting Problem ST-162 Mon, 24 May 2004 13:58 Go to previous message
Does your car have an alarm and immobiliser fitted?
I had a problem similar to this, took it to an auto electrician, he said the alarm could be draining the power away, he fitted a crank relay and I haven't had a problem with it since, it costed about $60
Previous Topic:Realistic registration/repair costs to get a car on the road
Next Topic:injector matching
Current Time: Sun Nov 1 11:52:15 UTC 2026
Total time taken to generate the page: 0.0056641101837158 seconds
