Toymods » Tech & Conversions » 4AGEZ or 3TGE??
sebta22
icon5.gif  4AGEZ or 3TGE?? Fri, 30 August 2002 09:08 Go to next message
Which is better 4AGZE or 3TGTE??
Is one better for finding parts?? Which is better for fitting into a TA22??
TE72_Turbo
Re: 4AGEZ or 3TGE?? Fri, 30 August 2002 10:26 Go to previous messageGo to next message
3TGTE is easier to fit because it was originally RWD, whereas a 4AGZE is only mounted east west in FWD corollas & MR2's. With a GZE you'll also have to change the flywheel & clutch, as it doesnt fit inside the RWD gearbox bellhousing.
Heaps more room left in the bay with a 4AGZE though, mine looks rediculously small sitting where the 3TGTE used to be.
I think there are more parts available locally for the GZE. They share a lot in common with the naturally aspirated 4AGE in regards to gaskets etc.
sebta22
icon7.gif  Re: 4AGEZ or 3TGE?? Mon, 02 September 2002 09:27 Go to previous messageGo to next message
Can i ask why you changed from 3T to 4AGZE engine?? Can you get the same power from 4AGZE?? or has the 3TGTEU have more options for power expansion
kingmick
Banned by his request
moved to tamworth
Re: 4AGEZ or 3TGE?? Mon, 02 September 2002 09:43 Go to previous messageGo to next message
if you want to keep the care light put the 4gze or build a 4agte, this will make a great balanced car. or if you want to spend less fit a 1ggte, but the balacne can never be the same.
mick
TE72_Turbo
Re: 4AGEZ or 3TGE?? Mon, 02 September 2002 12:21 Go to previous messageGo to next message
reasons I DONT like the 3TGTE (anymore)
- expensive to initially purchase
- old design (8 valve head) pushrod block
- heavy, large block & head
- weak pistons
- not as reliable at high revs (7k+)
- antiquated fuel only computer
- hard to source parts, read: expensive!
- noisy valvetrain/timing chain setup
- bulky distributor & twin coil setup, 8 plugs
reasons i DO like the late model 4AGZE
- cheap! & far more common than 3TGTE
- shares many parts with naturally aspirated 4AGE
- compact design, light weight
- 16 valve non-interference head
- better fuel & ignition computer
- direct fire ignition
- many aftermarket parts available
- forged, ceramic coated pistons from factory
- love to rev! restricted only by supercharger setup
just my opinion. I'm sure others have different experiences, both good & bad with each motor.
sebta22
icon10.gif  Re: 4AGEZ or 3TGE?? Tue, 03 September 2002 06:44 Go to previous messageGo to next message
Is there any benefits between 4AGE 20 valve and 4AGZE?? Is it simpler to install 4AGE 20 valve or does the 4AGZE have advantages of easier hp mods?
TA22-3SGTE
MACKAY
Re: 4AGEZ or 3TGE?? Tue, 03 September 2002 12:15 Go to previous messageGo to next message
Just go one better and do what I did , Bolt in a 3SGTE .
Trevor
sebta22
Re: 4AGEZ or 3TGE?? Sat, 07 September 2002 16:40 Go to previous messageGo to next message
4AGTE is sounding good what are the difficulties at installing into TA22? I have read that the inlet is the most shitty part is it true??
79rollaboy
NSW Engadine
Re: 4AGEZ or 3TGE?? Wed, 17 March 2004 05:21 Go to previous messageGo to next message
TE72_Turbo wrote on Mon, 02 September 2002 22:21
How in the hell can a DOHC engine have pushrods???
ke382TG
Re: 4AGEZ or 3TGE?? Wed, 17 March 2004 22:15 Go to previous messageGo to next message
It doesn't have pushrods, BUT the 3TGTE shares the same block as the rest of the 3T family.
Now, a 3T has a single cam and pushrods, and what Phil was getting at is that the 3TGTE block is a little larger than need be because the block has the tunnel bored in it for the 'in block' cam and pushrods, regardless of which 3T engine in the family it is. 2T's are the same deal, same block for the twin cams and the pushrod versions, just the bearing journals for the cam that would be located in the block have their oil ports blocked off in the twin cam versions.
79rollaboy
NSW Engadine
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 04:34 Go to previous messageGo to next message
my apologies TE72
does anyone know someone who has put a 3TGTE in a KE corolla?
I'd really like to talk to someone who has.. im thinking about doing it..
What gearbox do 3T-GTE's use.. i think its T50 but i read somewhere that they are very unreliable.
Also what sort of diff can i fit to my KE55?? It currently has a borg warner.. but im going to need a stronger diff if running a 3T.. Keep in mind it has leaf springs.
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 05:30 Go to previous messageGo to next message
3T-GTE used W55 gearbox from factory. A T50 can be fitted, by why would you want to? They are weak. Best to use the W55/7/8.
YelloRolla has one in a KE Corolla. Running low 11s I think?
79rollaboy
NSW Engadine
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 05:32 Go to previous messageGo to next message
SO how well do these W55's fit into KE corollas??
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 05:34 Go to previous messageGo to next message
Best to try contacting yellorolla on these forums as he has actually done it. Mine's in a RA28 which slipped straight in. But good chance the KE has a skinner tunnel?
79rollaboy
NSW Engadine
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 05:36 Go to previous messageGo to next message
Allready done...
What sort of diff are you using??
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 06:31 Go to previous messageGo to next message
sebta22 wrote on Fri, 30 August 2002 19:08
Wow this is an old thread!
[Updated on: Thu, 18 March 2004 06:32]
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 07:24 Go to previous messageGo to next message
but norbie - the kid has obviously been using the search function to do some research on putting a 3T-GTE into his KE55.... so i commend the lad!
Ill have a look at my mates KE20 with 3t-gte and see whats going on there....
79rollaboy
NSW Engadine
Re: 4AGEZ or 3TGE?? Thu, 18 March 2004 22:58 Go to previous messageGo to next message
Ok thanks guys.. i still have to figure out what sort of diff i have to use.. i was thinking about using a celica diff but im not really sure.
Carissa
Caboolture
Re: 4AGEZ or 3TGE?? Fri, 19 March 2004 03:43 Go to previous messageGo to next message
Thanks guys, it helps me too. I was trying to decide on which of the two to put in my ke35. thanks for the help!!
79rollaboy
NSW Engadine
Re: 4AGEZ or 3TGE?? Fri, 02 April 2004 03:44 Go to previous message
ANy word on your friends car that you were going to have a look at???
Previous Topic:corona questions
Next Topic:Electrical query
Current Time: Thu Oct 29 20:50:50 UTC 2026
Total time taken to generate the page: 0.0055251121520996 seconds
