Toymods » Tech & Conversions » 20V low comp pistons?
the dayo
20V low comp pistons? Mon, 24 May 2004 08:27 Go to next message
if i got a set of low comp pistons for a 20V would i then need to get new con rods, crank etc?
and does anyone know where to get such a product?
would normal low comp 4age pistons fit in?
Grega
melbourne.victoria.austra...
Re: 20V low comp pistons? Mon, 24 May 2004 08:47 Go to previous messageGo to next message
there is no such thing as a 20v low comp piston - the 20v pistons only come in hi comp dude.
its the GZE pistons such as the 8.9 and 8.0 to 1 comp which you can put in the motor to get the lower comp, and, yes they will fit.
the dayo
Re: 20V low comp pistons? Mon, 24 May 2004 09:21 Go to previous messageGo to next message
Would i need to get new conrods?
Dave
Re: 20V low comp pistons? Mon, 24 May 2004 09:39 Go to previous messageGo to next message
that depends on the piston pin diameter and pin height...
how long is a piece of string?
what are you trying to ask?
IRA11Y
Club Member
Re: 20V low comp pistons? Mon, 24 May 2004 11:17 Go to previous messageGo to next message
low comp 16V pistons will work but the head will no longer be non interferance, i assume you are planning a turbo?, as long as you get the cam timming right there wont be an issue if you are after the low comp 16V pistons send me a PM i may be able to help you out with pricing.
as long as you are carefull with the boost there is no need to change the rods and crank, standard they are fairly strong items.
Re: 20V low comp pistons? Mon, 24 May 2004 12:45 Go to previous messageGo to next message
From the information i have got, the crank for the AE101 20V and GZE is actually a shared item! (same part number) Damn strong too!
However, the rods are definitely different from the 20V to GZE. GZE ones are obviously much beefier.
But like IRA11Y said, with the right setup, its all good within its limitations
MR. 2
Parramatta
Re: 20V low comp pistons? Mon, 24 May 2004 22:45 Go to previous messageGo to next message
one thing that comes to mind, i think i cant be 100% sure that, but dont the 20v pistons have a special cut out withing the piston for the extra valve???
Grega
Re: 20V low comp pistons? Mon, 24 May 2004 22:54 Go to previous messageGo to next message
yes they sure do!
so you'd need to flycut for the extra valve..
jasonp1977
Re: 20V low comp pistons? Mon, 24 May 2004 22:55 Go to previous messageGo to next message
...guess what Witzl...
The AE101 GZE and 1st gen 20V share the same rods aswell...
They are a bit lighter than the late AE92 GZE rods.
IRA11Y
Club Member
Re: 20V low comp pistons? Tue, 25 May 2004 06:24 Go to previous messageGo to next message
nope, again if you set the timing right you wont need to add the extra flycut to the ACL low comp pistons.They are allready dished, almost id bet, to the point where it may still be a non interferance head.
Flogbag
Sydney (Campbelltown...!)
Re: 20V low comp pistons? Tue, 25 May 2004 07:29 Go to previous messageGo to next message
wow wow wow
so let me get this right
GZE and 20V share the same rods and crank just use different pistons?
if so there wouldnt be much need for agressive cams to be put into a 20v would there?
jasonp1977
Re: 20V low comp pistons? Tue, 25 May 2004 07:34 Go to previous messageGo to next message
13401-16020 CRANKSHAFT 01.06.1991-01.08.1998 4AG#..AE101
13201-19126 ROD SUB-ASSY, CONNECTING 01.10.1991-01.05.1995 4AG#..AE101
Those are the part numbers for the ae101 GZE and series 1 20V, I cant comment on the series 2 silvertop 20V as I can't be bothered looking up the part numbers for it as I dont have a series 2 VIN.
TerryOBeirne
Redbank Plains,near Ipswi...
Re: 20V low comp pistons? Tue, 25 May 2004 07:54 Go to previous messageGo to next message
the later 20V (blacktop) rods and pistons are both different to earlier engines. its relatively easy to cut the valve inserts in the pistons, we do it all the time on race engines.
Johnny
Sydney, OZ
Re: 20V low comp pistons? Tue, 25 May 2004 11:46 Go to previous messageGo to next message
I think they are too, the 20V pistons are really domed from memory, I've got some, just need some GZE ones to compare them to...
the dayo
Re: 20V low comp pistons? Wed, 26 May 2004 05:18 Go to previous messageGo to next message
where would one grab hold of a set of pistons? how much would they go for?
IRA11Y
Club Member
Re: 20V low comp pistons? Wed, 26 May 2004 06:06 Go to previous messageGo to next message
Dayo, give me a call, i think i have a set here brand new that have been balanced but never used.
IRA11Y
Club Member
Re: 20V low comp pistons? Wed, 26 May 2004 06:09 Go to previous messageGo to next message
jhonny ive got heaps of old pistons laying about if you want to sort thru them and take one for testing
Buster
Re: 20V low comp pistons? Wed, 26 May 2004 11:41 Go to previous messageGo to next message
Hi Guys, sorry to barge in but one of my mates has a set of gze slugs he has offered to sell me but I don't know how much they are worth any ideas ? They are second hand but have not been used since the engine was shipped from Japan as he has used forged units, they look in good order, any advice would be appreciated !
Re: 20V low comp pistons? Wed, 26 May 2004 12:04 Go to previous message
brand new from toyota, the 8.9:1 late model GZE (smallport) variants are worth <$400.
Previous Topic:Throwout bearing for AE71/AE86
Next Topic:what clutch do i use
Current Time: Thu Nov 19 10:24:25 UTC 2026
Total time taken to generate the page: 0.0090630054473877 seconds
