Toymods » Tech & Conversions » 3SGTE into an RA60 5 speed, what mods are needed?
NILE8U
Glenmore park, Sydney
3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 13:37 Go to next message
i'm interested in putting a 3SGTE into an 1983 RA60 celica? what has to be done?
gabe
Re: 3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 13:47 Go to previous messageGo to next message
Ill quickly jump in here before you get bombarded with "Do a search!" from everyone here.....
Seriously though this topic has been covered A LOT, and the search feature of the site is handy, all your questions will most probably be answered here.
But seeing as im here.......
Custom intake
Custom exhaust
Custom engine mounts
Custom gearbox mount
Custom shitloads of other stuff
Probably an aftermarket ECU due to the fact you cant run a dizzy because it conflicts with the firewall
Same with the water outlet on the back of the head
Thats the first half of the list, theres lots of other things that need to be taken into consideration.
And I think just being 'interested' is not enough to put a 3S in RWD configuration, lots of time and money helps also.
Re: 3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 14:19 Go to previous messageGo to next message
Gabe,
As a side note, could you use any of the mounts from an SA63?
gabe
Re: 3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 14:29 Go to previous messageGo to next message
I believe you can yes.
I just listed what I did. Doh! Razz
Well picked up! Smile At least someones paying attention.
[Updated on: Mon, 24 May 2004 14:31]
CLG
Perth, Western Australia
Re: 3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 15:59 Go to previous messageGo to next message
Have you seen the size of factory 2S RWD engine mounts??? If they bolt into an RA60 fair enough, use them, but any installer will be much better off making custom mounts for other installation.
Re: 3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 16:01 Go to previous messageGo to next message
Nope, what they look like? Pissy?
CLG
Re: 3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 16:11 Go to previous messageGo to next message
No other way - they're bigger than your dick in the morning, which while I've heard ain't all that big, they're still big and bulky!
Re: 3SGTE into an RA60 5 speed, what mods are needed? Mon, 24 May 2004 21:21 Go to previous messageGo to next message
I used half of the 2S mounts Rolling Eyes
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 00:07 Go to previous messageGo to next message
May as well use the SA63 bellhousing, mounts, crossmember, etc. - you'll still need a custom flywheel etc. though, and would be highly advised to make a custom sump while you're at it.
gabe
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 00:56 Go to previous messageGo to next message
mrshin wrote on Tue, 25 May 2004 08:07
I used the standard 3S flywheel....had to slot a starter motor bolt hole about 5mm though
rvrolla
Central Coast
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 01:59 Go to previous messageGo to next message
Just a quick question, it seems a fair bit of work gettin a 3S in pretty much anything Razz but if you sarted off with a SA63 and removed the 2S is it still allot of effort to fit in a 3S? What would be easier in this case? A 3S or a 1G?
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 02:00 Go to previous messageGo to next message
A 3s in RWD is always going to be hard no matter what you start with. So the 1G would be much easier.
rvrolla
Central Coast
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 02:02 Go to previous messageGo to next message
Oh ok, isnt there any RWD 3SGTE's?
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 02:07 Go to previous messageGo to next message
No, the only RWD 3S is the Altezza's 3SGE isn't it?
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 03:36 Go to previous messageGo to next message
Thats correct.
NILE8U
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 03:58 Go to previous messageGo to next message
what would be the easiest, four banga turbo motor to put into one?
Re: 3SGTE into an RA60 5 speed, what mods are needed? Tue, 25 May 2004 04:00 Go to previous message
3TGTE?
Previous Topic:CA18DET in ta22
Next Topic:high hp powered ta22, wat mods needed?
Current Time: Thu Oct 22 04:52:30 UTC 2026
Total time taken to generate the page: 0.010288000106812 seconds
