Toymods » Tech & Conversions » high hp powered ta22, wat mods needed?
freakincage_com
north brisbane
high hp powered ta22, wat mods needed? Mon, 24 May 2004 23:45 Go to next message
hey guys i'm going to b puttin a ca18 det into my celica...its currently in the shell stage and i am removing all the rust and was woundering if there where any places that might need strengthning? and what suspention and brake upgrades? and are 4spot calipers needed? what about diff?? i'm hoping to get 200hp on the stock ca18(herd its easy to do and its stable) and later on put a bigger turbo, comp, ect.
[Updated on: Mon, 24 May 2004 23:47]
gold28
Madrid - Spain
Re: high hp powered ta22, wat mods needed? Tue, 25 May 2004 00:18 Go to previous messageGo to next message
Your 22 should swallow 200hp without batting an eyelid.
If you are wanting more than that though, I would consider stitching the seams and adding bracing on the front struts. The rear is relatively stiff but through the cockpit, it isn't great. You won't fix this area easily without a cage.
I would be looking at a diff improvement while your at it.
You would be very foolish to upgrade acceleration and handling without doing the brakes. THere is heaps on these forums about them so go searching.
YOGI8U
up yours!
Re: high hp powered ta22, wat mods needed? Tue, 25 May 2004 02:28 Go to previous messageGo to next message
chassis needs work.
I had my rails lengthened to join the front and rear.
before that, with a good hit the boot would sometimes open and the doors became hard to close....chassis twisting.
I have heard of sill twisting, but haven't seen it yet.
CLG
Perth, Western Australia
Re: high hp powered ta22, wat mods needed? Tue, 25 May 2004 03:20 Go to previous messageGo to next message
Yep, stitch weld everything, move the gearbox crossmember mount to suit, and weld in roll cage if you want to go mass horsepower, ..., but then again, 200HP isn't mass horsepower!!!
Re: high hp powered ta22, wat mods needed? Tue, 25 May 2004 03:28 Go to previous message
just remember the ta22 weighs about as much as a biscuit, so 4-spot calipers are overkill - some decent 2-spots will stop it just fine
Previous Topic:3SGTE into an RA60 5 speed, what mods are needed?
Next Topic:AE86: springs n shocks setup
Current Time: Sun Oct 18 20:01:07 UTC 2026
Total time taken to generate the page: 0.0051939487457275 seconds
