Toymods » Tech & Conversions » Remote turbo
SupraPete
Remote turbo Tue, 25 May 2004 01:08 Go to next message
http://ststurbo.com/home
1 Would this work?
2 What would the turbo sizing be? (eg. for a 3L, a good turbo would normally be x but with this setup it would be y)
3 Would the turbo be smaller to reduce lag from that distance?
4 Would having thinner pipes before the turbo on the exhaust side) help reduce lag?
5 Would it be worth setting up dual turbos (one blowing into the other) to reduce lag/more boost from that distance.
Re: Remote turbo Tue, 25 May 2004 02:07 Go to previous messageGo to next message
1) sure it'd work a bit...
the motors they use them on are not exactly what you'd call efficient, and anything you do to help will give big improvements. can you say "thaats myyy truuuuck"
basic thing is that turbos require energy to spin.. this means exhaust temperature and velocity.. (as well as pressure between motor and turbo)
the further away you put the turbo, the lower the exhaust energy will be (and exhaust pressure is lower), and so the less energy there is available to spin the turbine..
smaller turbine = smaller compressor = less air moved..
you would need a smaller turbo at this position to reduce lag, but you wil also not get much benefit from it since the compresor will also be smaller...
it might be good on large capacity, low revving motors with limited range of rpm...
4. probably... but would you want to deliberately reduce the size of your exhaust?? again, good for limited rpm perhaps....
although it is a good idea to move hot turbo away from engine bay.. think of it as just running a 3m turbo manifold, and 3M inlet back to engine... thats a lot of volume of gas before and after the turbo!!!
i guess basically.. smaller turbo, smaller benefit... could be a good solution if you only want 2 or 3psi perhaps....
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Remote turbo Tue, 25 May 2004 02:17 Go to previous messageGo to next message
Hmm.. I think people figured out sometime in the 80's that running turbos without intercoolers is bad. MKay?
I'd imagine the lag would be quite hideous too.
Things would also get hot underneath the car...
And it'd be fun to have that air filter down there when it rains...
They also don't mention how they cool the turbo apart from mentioning their "patented system".
So, to sum up... Hot air into engine. Lots of lag. And heaps of weight.
MR. 2
Parramatta
Re: Remote turbo Tue, 25 May 2004 02:30 Go to previous messageGo to next message
thats a good idea, for a smaller budget... but i would only think that this would give you small gains and wouldnt be quite as effeicent as the convential way, if that power gains i dont think would be quite as good as the convential way. You will have a lot more lag due to the exhaust gases have to travel alot more, also i dont think that the the inlet side with the piping being so far is such a good thing either.
but you will never know until u try.
Henn
Rosanna, Melb
Re: Remote turbo Wed, 26 May 2004 10:02 Go to previous messageGo to next message
I read a bit about this and had a laugh, but the more I thought about it the angrier I got. A lot of the "technical info" given on the STS website is crap, for example they claim it is good to have cool dense exhaust entering the turbo. In fact it is best to keep it as hot as possible, just look at the F1 teams in the turbo era, they used heat wrap. If these guys are so willing to spout crap left, right and centre, do you really want to buy anything off them??
It may be ok if you want a fullsik turbo on the cheap and nasty, but hello lag, no intercooler, extra oil pump, air filter under car etc. In my opinion, if you are going to do something, do it properly. And if you want to offload a whole packet of money, at least give it to some needy charity.
Hen
Re: Remote turbo Thu, 27 May 2004 06:30 Go to previous messageGo to next message
but remember this is aimed at the US 'domestic' truck market...
those things rev so slowly and are geared so low the the turbo probably has time to spool up Very Happy
and even if it only just gives 2psi boost, it's still going to make the big ol' engine much more torquey than stock....
not exactly a performance option... more of a long haul towing a caravn kind of option...
and an afterthought Wink
STR8 2.8
Re: Remote turbo Thu, 27 May 2004 08:03 Go to previous messageGo to next message
WOAH Welcome to lagville!
thats fantastically lagarific
SupraPete
Re: Remote turbo Thu, 27 May 2004 09:35 Go to previous messageGo to next message
Has anyone actually done it and can show that its laggy?
Re: Remote turbo Thu, 27 May 2004 09:38 Go to previous messageGo to next message
Jamie (of TT 1UZ fame) now actually has a single turbo that is remote mounted.
Nark
Cabramatta, NSW
Re: Remote turbo Thu, 27 May 2004 09:55 Go to previous messageGo to next message
Under the diff?
bbaacchhyy
Re: Remote turbo Thu, 27 May 2004 14:48 Go to previous messageGo to next message
Nark wrote on Thu, 27 May 2004 19:55
Under the diff?
Not quite, it's just behind and below the passenger front seat. I've seen it before it was fully hooked up, and as usual it was a piece of art.
When he was driving it gently from his place to his old mans, it was starting to provide flow from just off idle. One thing was certain, it had a GREAT exhaust note !!!
Michael B
SupraPete
Re: Remote turbo Fri, 28 May 2004 03:49 Go to previous messageGo to next message
Do you know if he modified the floorpan to put it in?
And yes, I'd assume it was a work of art. Jamie does wonderful work.
bbaacchhyy
Re: Remote turbo Sun, 30 May 2004 12:43 Go to previous messageGo to next message
You could say there were a few mods, but the solution was very elegant, and the floorpan distruptions were minimal.
JustenGT4 may have a better idea of how it ended up, but at the moment, I think Justen's beasty has spurned Jamie back into action on the TA22.
Michael B
4agte
Toronto, Downtown
Re: Remote turbo Tue, 11 January 2005 21:24 Go to previous messageGo to next message
lagg city id say and theyh dont mention an intercooler either
feral4mr2
Bundaberg, Qld.
Re: Remote turbo Tue, 11 January 2005 22:06 Go to previous messageGo to next message
a thread about these came up on the mr2oc the other day.
http://chevyhiperformance.com/techarticles/148_050 2_turbo/
Kyosho
Wollongong
Re: Remote turbo Wed, 12 January 2005 05:09 Go to previous messageGo to next message
4agte wrote on Wed, 12 January 2005 08:24
Actually it doesn't lag more...
There are quite a few cars in America running turbos mounted at the back of the car underneath...
The only problem they have is in the rain...
And theft...
So much easier to steal the turbo from under the car then under the hood...
4agte
Toronto, Downtown
Re: Remote turbo Wed, 12 January 2005 08:26 Go to previous messageGo to next message
Kyosho wrote on Wed, 12 January 2005 16:09
And theft...
If i had a truck with a 5.7 ltr engine it probably wouldnt be laggy.
Necros
Re: Remote turbo Wed, 12 January 2005 09:55 Go to previous messageGo to next message
Im definately giving it a thumbs down...
Reason #1:
Exhaust gases are much hotter and move faster closer to the engine.
Reason #2:
No intercooler
Reason #3:
Those so called trucks are so god damn big why would there be any trouble in placing a turbo in the engine bay!? Sounds a bit half arsed and lazy to me.
But thats not to say that remote mounting isnt a go... Just not that way in my opinion Smile
turbokid
Re: Remote turbo Wed, 12 January 2005 10:47 Go to previous messageGo to next message
Would be much better if they had it placed up near the gearbox. The exhaust gas has to travel all the way through cat down to the diff, I mean come on, they could have designed it a little better.
And for under 4k US?? What a bargain Rolling Eyes
Toobs
Re: Remote turbo Wed, 12 January 2005 12:34 Go to previous messageGo to next message
I suppose some of the pressure drop caused by all the plumbing could be made up for a bit by the location of the CAI... And manifold design doesn't really pose a problem with one of those puppies.
Colder exhaust air hitting exhaust wheel means less heat being transferred to the intake and so could in some cases defeat the need for an intercooler... cheap and nasty intercoolers and poorly routed pipework cause quite a pressure drop.
I'd imagine cops would be less likely to notice your turbo if it was near your diff too.
Theres no way it could compare to an the under hood mounted turbo with a decent manifold and CAI though... but for people trying to squeeze a turbo into a car that already has a V8 engine shoved in a straight 6 sized engine bay it could have some great benifits.
Re: Remote turbo Wed, 12 January 2005 14:32 Go to previous messageGo to next message
Toobs wrote on Wed, 12 January 2005 22:34
Almost all of the heat introduced into the system comes from compressing the air (Boyle's law), not heat transfer from the exhaust side, so cooler exhaust will make fark all difference to inlet temps.
Having said that, the huge length of pipe from the turbo to the throttle body will probably act as a fairly decent intercooler... forget about throttle response though! Laughing
Kyosho
Wollongong
Re: Remote turbo Thu, 13 January 2005 04:39 Go to previous messageGo to next message
Pressure drop...
Did you know that is one thing you WANT in an intercooler?
If you don't get a pressure drop, you
a) Don't require an intercooler because the air is cool enough already
b) Aren't running a high enough PSi to warrant an intercooler which also falls partly under (a)
The reason you get a pressure drop is because cooler air is more dense, meaning less pressure...
1UZ FTE
Re: Remote turbo Thu, 13 January 2005 05:15 Go to previous messageGo to next message
Hi Guys
I was going to reply to this thread way back in May/June last year and it completely slipped me until now
hmmm yes i did do a remote turbo location on the 22 1uzfe ,...it was placed just behind the passengers front seat ,.so basicaally in the cabin and rear seat footwell with boxing placed over the top + heat sheilding
the intercooler was placed where the rear seat usually goes and was a water/air setup with the rad part in the boot with a large thermo fan pulling air across it from under the car ,...
3" stainless piping ran to the front butterfly along the tunnel (all still inside the cabin)
The Turbo was the GT35-40 (700hp) model with the 1.06 rear housing fed by 4 into 1 extractors + 2 twin 2.5" stainless pipes joining just at the turbo
some have mentioned lag,.. yes and no is the answer ,...
the lag came if you had not brought the car on boost for awhile and i beleive this is due to all the pipe work cooling down and pulling alot of the heat out of the exhaust temp ,..it was quite noticable
once everything was hot the lag was minimal even un-noticable
boost response was not savage either compared to the twins i originally ran ,.but i can't clarify if this was due to the remote location or just the single swap
performance resulted in the car making 310rwkw on 1bar boost on a dyno dynamics dyno under constant load
The turbo is now on it's way back into the engine bay due to engineering issues with it in the cab not to mention the induction roar when you got stuck into it
SupraPete
Re: Remote turbo Fri, 14 January 2005 07:28 Go to previous message
Sounds like a lot of work Jamie. Pity you've got to move it again.
Previous Topic:permenantly removing car aerial...
Next Topic:hydraulic clutch conversion in ke35
Current Time: Sat Oct 17 15:30:48 UTC 2026
Total time taken to generate the page: 0.008267879486084 seconds
