Toymods » Tech & Conversions » 4age (blue top) into ke35
Carissa
Caboolture
4age (blue top) into ke35 Tue, 25 May 2004 02:37 Go to next message
hi guys, i have got my blue top 4age sitting out the back, my ke35 down town (broken down). i think its about time i start my conversion. My intake manifold is modified to suit my RWD application (air intake on the front side, rather than the rear) I have seen a few pictures, and im a little worried the brake master cylinder will get in the way of the intake.
i have the japanese master, that sits on the drivers side, at the top of the engine bay, and tends to hang foward a fair way. anyone think this will be a problem??
Also the age old question, who has done it, and what do you reccomend: do i need to change the standard metal fuel line to feed a little more juice to my 4age? and, how have you hookedup your gauges when the 4k motor and k50 gearbox (usually a 3k in this model) use cable drive and the 4age and t50 use electronic gauges?
Ive been searching the forums and finding very little useful info, so any imput would be appreciated.
Thanks!
Re: 4age (blue top) into ke35 Tue, 25 May 2004 02:46 Go to previous messageGo to next message
ask Demuire ... KE35, 4AGE... should be info on this forum about it.. if not PM him..
CLG
Perth, Western Australia
Re: 4age (blue top) into ke35 Tue, 25 May 2004 02:55 Go to previous messageGo to next message
The only way you'll find out what fits and what doesn't is by trying to fit it, once you determine what will work and won't, you can ask more specific questions that will be easier to answer.
You can keep your cable clutch by using a K50 five speed behind your 4AGE, or you will have to convert to hydraulic clutch if you want to use a T50 gearbox. Instrument wise, take the sender for the guages off your 4K engine, install them into your 4A engine, and all your guages will work as before. THe guage needs a compatible sender to work properly, and simply swapping them over is your easiest option.
Clint
wombat
Laverton, Vic
Re: 4age (blue top) into ke35 Tue, 25 May 2004 03:51 Go to previous messageGo to next message
hey I'm considering doing the same conversion. if ya get some info send it along. also curious on engine mount situation.
also did the 4agze come as RWD? if not how hard to convert it over to RWD?
Dodgy_Haro
Re: 4age (blue top) into ke35 Tue, 25 May 2004 06:29 Go to previous message
oldcorollas wrote on Tue, 25 May 2004 12:46
Otherwise try the Old Corollas forums - he has been updating everyone on his progress.
That said, you can check out his own personal webpage at Planet Fookstar ...
http://fookseung.fotki.com/
Previous Topic:2TG-18RG timing chain tensioner
Next Topic:CA18DET in ta22
Current Time: Fri Oct 23 10:27:42 UTC 2026
Total time taken to generate the page: 0.0058329105377197 seconds
