Toymods » Tech & Conversions » anyone put an oil pres. gauge on a 4AC?
45aken
NSW.south coast.Drifting
icon5.gif  anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 04:27 Go to next message
anyone done this? where do i get the mechanical signal from? any help?
its for an ae86
pro_ke
adelaide
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 04:41 Go to previous messageGo to next message
im just going to assume that the A series are reasonably similar to K series. where you spin the oil filter onto might be an alloy block that then bolts to the motor, get that block drilled and tapped to accept the sender unit, if you cant do it yourself it shouldnt cost more than $20 if you needed to pay someone to drill + tap that.
pro_ke
adelaide
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 04:43 Go to previous messageGo to next message
replace the words 'sender unit' with 'fitting' for a mechanical gauge, sorry i thought you meant an electric one - same theory applies though.
45aken
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 05:08 Go to previous messageGo to next message
does this mean that oil will be going into my gauge? i though only air was meant to go through the nylon pipe??? my bad! hmmm wouldn't want that to leak Smile
can anyone else back this up???
pro_ke
adelaide
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 05:24 Go to previous messageGo to next message
if it is a mechanical gauge you will have oil going up that tube to wherever you mount the gauge itself
if its an autometer one put the nylon hose in the bin and buy the braided line kit.
ab
45aken
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 08:15 Go to previous messageGo to next message
nah its OBX (not as good as autometer). should i be worried about the nylon line???
serge
western suburbs,sydney
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 08:20 Go to previous messageGo to next message
Just use good quality lines & fittings & you'll be right!!!
[Updated on: Tue, 25 May 2004 08:21]
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 09:44 Go to previous messageGo to next message
Stocky gauge not good enough for ya, ey?? Shocked
ed_ma61
Lost in the K hole
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 09:48 Go to previous messageGo to next message
45aken wrote on Tue, 25 May 2004 18:15
should you be worried about engine fires ?? Confused
YelloRolla
On your mum!
Re: anyone put an oil pres. gauge on a 4AC? Tue, 25 May 2004 09:57 Go to previous messageGo to next message
You can usually buy an adapter (maybe fuel miser brand of haig?) to fit in the tapped hole for the idiot light, then you can run the idiot light and the pressure gauge simultaneously.
45aken
Re: anyone put an oil pres. gauge on a 4AC? Wed, 26 May 2004 07:35 Go to previous messageGo to next message
stocky gauge broken, i think i might just wait til the blue top goes in Smile
[Updated on: Wed, 26 May 2004 07:36]
Re: anyone put an oil pres. gauge on a 4AC? Wed, 26 May 2004 08:06 Go to previous messageGo to next message
Pricol electrical oil pressure guage = $30
Pricol electrical oil pressure sender = $30
NPT thread adaptor from Motorsport Connections = $5.
Install where idiot light was. DONE.
45aken
Re: anyone put an oil pres. gauge on a 4AC? Wed, 26 May 2004 15:05 Go to previous message
new obx oil pressure gauge(all lines/fittings etc) - $25
having no idea how to put it on 4AC so put in 4age when i get it - $priceless
trusty ebay
Previous Topic:apexi S-ITC on 4age
Next Topic:Throwout bearing for AE71/AE86
Current Time: Thu Nov 19 08:15:23 UTC 2026
Total time taken to generate the page: 0.010318040847778 seconds
