Toymods » Tech & Conversions » apexi S-ITC on 4age
45aken
NSW.south coast.Drifting
apexi S-ITC on 4age Tue, 25 May 2004 08:56 Go to next message
just wondering the gains/advantages of the apexi S-ITC ignition timing controller on a bigport 4AGE?
when i get around to turbo'ing the engine, if i add a S-AFC air flow controller, will there be no need to have a new replacement ecu (eg microtech etc?)
or should i just save my pennies and buy the MTX-8?
Chris Davey
sunny coast, qld
Re: apexi S-ITC on 4age Tue, 25 May 2004 12:06 Go to previous messageGo to next message
aren't MTX8's pretty cheap? I would go that way if I were you. The only reason I am going to use a fuel computer is that I need an LTX12 which is a lot dearer than an MTX8.
Ribbo
Northern Beaches
Re: apexi S-ITC on 4age Tue, 25 May 2004 22:12 Go to previous messageGo to next message
from what I have heard you just end up sepending lots of money on individual components as you hit the limit of 1 you need another different one. Better off just getter a standalone computer first.
45aken
Re: apexi S-ITC on 4age Wed, 26 May 2004 07:52 Go to previous messageGo to next message
thats what i was thinking, just alot of nice, pretty things on the dash=less power than one under the carpet
quest
u.s.a. south
Re: apexi S-ITC on 4age Wed, 26 May 2004 17:02 Go to previous message
piggyback timing controllers are a decent alternative. You will want to retard your timing under boost when you start to push your combination. A fuel controller will only get you so far. MSD boost timing master is another such, adjustable unit and has been run sucessfully on 12, 11 and 10sec daily drivers. Piggybacks work.
safc + btm + stock ecu is very common. Most folks buy them used, so its hard to beat the dollar value.
Previous Topic:4age 20 valve VS 4AGZE
Next Topic:anyone put an oil pres. gauge on a 4AC?
Current Time: Thu Nov 19 10:03:06 UTC 2026
Total time taken to generate the page: 0.00543212890625 seconds
