Toymods » Tech & Conversions » TRD Quick Shift Kits
Alchemist
icon5.gif  TRD Quick Shift Kits Tue, 25 May 2004 13:53 Go to next message
Hi Guys,
I'm contimplating a TRD quick shift kit for my SW20, they seem to be $350 or so, just wondering if anyone has got one of these in a SW20 or any TRD quick shift kit? Are they worth the money? A noticable difference in gear shifting? Does the gear knob look ok? Laughing
Sounds rather stupid, I'm guessing they dont come with installation instructions? Are they easy to install(SW20)?
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: TRD Quick Shift Kits Tue, 25 May 2004 14:25 Go to previous messageGo to next message
yes TRD quick shifts work, they make the shift quicker and shorter with the same time it normally takes to shift. If you shift even quicker all the time this will lead to syncro wear.
you dont get a knob with the kit
ae86drift
sydney.au
Re: TRD Quick Shift Kits Tue, 25 May 2004 17:58 Go to previous messageGo to next message
i got a knob with mine!
.... his name was simon hehehe
ahhahha. no. but seriously i did get a knob. a leather one.
takai
Re: TRD Quick Shift Kits Wed, 26 May 2004 01:25 Go to previous messageGo to next message
While not on the SW20 topic i have heard bad things about the TRD T50 short shifters, mainly with the angle that they shift at and the shaft length causing bad vibrations under load and often popping out of gear.
This has happened to one i was in, but i cant conclusively say it was the shifter's fault and not the T50.
I got a C's one for reference.
MR. 2
Parramatta
Re: TRD Quick Shift Kits Wed, 26 May 2004 02:52 Go to previous messageGo to next message
i have a trd quick shift for my sw20
the shift is shorter, but not by much at all, considering the size of the std sw20 shifter, its not worth the 350$$$ i got mine for 160 with a leather trd knob thats worth it....
penrith toyota give them a ring thats what i got mine for!
[Updated on: Wed, 26 May 2004 02:59]
Joshstix
Toymods Vice President
Re: TRD Quick Shift Kits Wed, 26 May 2004 05:36 Go to previous messageGo to next message
You can make your own short shifter for practically nothing.
All the TRD short shifter does is move the tab for connecting the shift cable further up the stick. You can pull the shifter apart, grind off the tab and then weld it on further up the stick.
I did this with my AW11 about 2 years ago and it worked like a charm even with the terrible welding I did with a dodgy old stick welder. I did however redo it recently and get it welded well, but that is because I wanted to shorten the shift further. The problem with moving the tab too far up the stick is that the shift cable will rub on the centre console, this can be fixed by making a spacer to go between the plate that bolts to the floor and the shifter bolt face.
[Updated on: Wed, 26 May 2004 05:37]
Senor_2
Re: TRD Quick Shift Kits Wed, 26 May 2004 07:14 Go to previous message
Check out this site:
http://www.geocities.com/MotorCity/Factory/8762/sh ifter.htm
Gives the specs for the TRD shift kit so u can make ur own, save the ca$h and get the same results
Previous Topic:Connecting up 100kw intake to GZE?? PICS INC
Next Topic:Shock rebuilder - Perth
Current Time: Thu Nov 19 18:43:39 UTC 2026
Total time taken to generate the page: 0.0059120655059814 seconds
