Toymods » Tech & Conversions » T50 Leak....
SPEEDCORE
GoldCoast/Brisbane
T50 Leak.... Wed, 26 May 2004 09:59 Go to next message
Hi guys/gals....
Filled up the g'box in the sprinter on the weekend and drove it into the gargage... today came home and saw that there is a leak.... checked where it is comming from and it is not from the drain plug.... rather it is somewhere near where the driveshaft bolts onto the back of the g'box right at the back....
I gather there is a seal there that is not doing its job.... what is the name of it (so I can order it) and what would be the difficulty of changing it??
Thanks,
Speedy.
fOOZ86
Re: T50 Leak.... Wed, 26 May 2004 10:27 Go to previous messageGo to next message
you know I think I have the same problem, I had a look under today and there's all this oil spashed up around where the gearbox connects at the back.. not good!
earlyrolla
Re: T50 Leak.... Wed, 26 May 2004 10:37 Go to previous message
I assume you mean where the tailshaft yoke (slider) fits into the back of the gearbox?
In which case it is simply the rear gearbox seal. Not an uncommon problem, they take a far bit of abuse (the rear gearbox seal).
I have changed ones in W50 boxes before, had to make a special puller to get the seal out. Depends on how rough you want to be I guess.
Previous Topic:what clutch do i use
Next Topic:1G-GTE SAFC help!
Current Time: Thu Nov 19 12:55:36 UTC 2026
Total time taken to generate the page: 0.0069139003753662 seconds
