Toymods » Tech & Conversions » Toyota Axle codes
Alainve
Newcastle NSW
icon5.gif  Toyota Axle codes Sat, 31 August 2002 10:12 Go to next message
What is the axle code for the RA60 Celica i have found some where that it is an 'F'. is this axle interchangeable with the earlier axle used on the TA22-RA28? .
i know the widths are different but do the suspension mounting points line up?
Also where is the Id number printed on the axle or diff housing? i have an axle assembly whole and out of a car but i cant find the codes printed on it anywhere, (its still dirty tho).
Re: Toyota Axle codes Sat, 31 August 2002 13:25 Go to previous messageGo to next message
All live-axle RA60 Celicas have T series diffs (at least all the ones I've seen). Some SA63 and RA65 Celicas have F series diffs, but they all have IRS which obviously is not interchangeable with earlier live-axle Celicas.
I don't think the axle code is stamped anywhere on the axle housing, you have to look at the build plate in the engine bay to find that.
RA28
Re: Toyota Axle codes Sun, 01 September 2002 01:29 Go to previous messageGo to next message
I think if you have a diff and don't know what it is out of it is hard to find out. if it is a RA60, it should be a 4.1:1 and will also have sway bar mounts. The 23/28/40 difs didn't have these I think. I have a ra60 rear axle setup in my shed so if you need to know I could look over it for you.
Tim.
rob_RA40
c'town, NSW
Re: Toyota Axle codes Sun, 01 September 2002 01:52 Go to previous messageGo to next message
RA60 is actually 3.9:1
Re: Toyota Axle codes Sun, 01 September 2002 01:59 Go to previous messageGo to next message
IF they sort of follow Mk2 Supra convention in Aus, I think you may find the manual RA60's had a 3.9:1 (like mine) and the auto's may have had 4.1:1...
Can anyone with auto RA60 confirm this?
Alainve
Newcastle NSW
Re: Toyota Axle codes Sun, 01 September 2002 09:02 Go to previous messageGo to next message
this is the site Ive got some info from, its not very specific when it comes to the later model stuff but its good otherwise
http://ourworld.compuserve.com/homepages/stepho/di ff.htm]
the diff i have is definitely from a RA60
Alainve
Newcastle NSW
icon14.gif  Re: Toyota Axle codes Sun, 01 September 2002 09:05 Go to previous message
that site didnt come out right here its is again Embarassed
Previous Topic:1GGTE + KE70 rolla and Diff to suit?
Next Topic:what coolant????
Current Time: Wed Oct 21 02:58:05 UTC 2026
Total time taken to generate the page: 0.0051140785217285 seconds
