Toymods » Tech & Conversions » reversing output of SC12/14
VL_Commy
reversing output of SC12/14 Wed, 26 May 2004 15:59 Go to next message
hey guys,
I have just bought myself a 1981 honda civic, and i have plans to supercharge it using an SC12/14. Problem is, honda engines rotate in the opposite direction to toyotas. which brings about my question, will an SC12/14 still work if spinning in the opposite direction? will it be a simple matter of using the inlet side, as the outlet side? if not is there a way that i can get it to work backwards?
i found the attached picture of a SC12 with the rear end removed, exposing the gears. if i switched the sides that the gears are on and rotated the pulley in the opposite direction, would that actually do anything??
http://home.iprimus.com.au/terryallen/sc12open.jpg
[Updated on: Wed, 26 May 2004 16:00]
M.W.P.
Rocky Mountains, Canada
Re: reversing output of SC12/14 Wed, 26 May 2004 16:34 Go to previous messageGo to next message
Someone asked this exact same question like a week or two ago.
Do a search.
VL_Commy
Re: reversing output of SC12/14 Thu, 27 May 2004 02:05 Go to previous messageGo to next message
yeh i asked the question, cant find the thread anymore. Did a search, nothing comes up.
earlyrolla
Re: reversing output of SC12/14 Thu, 27 May 2004 11:08 Go to previous messageGo to next message
There is no real problem (IMO) in running the SC14 backwards and just swapping the inlet and exhaust since the SC14 doesnt run twisted rotors.
That said, a possible problem might be the reversing of the side of the teeth on the gears that take the load. Kind of suck it and see.
Make sure that if you pull the SC14 apart that you mark the gears and they go back together in EXACTLY the same mesh. This is a good idea as the teeth wear in a particular pattern.
Re: reversing output of SC12/14 Thu, 27 May 2004 11:18 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=showposts &id=4039&rid=1976&S=1fac496d2e05330a3b c25caad4f4ffab
[Updated on: Thu, 27 May 2004 13:31]
earlyrolla
Re: reversing output of SC12/14 Thu, 27 May 2004 11:49 Go to previous messageGo to next message
Nice Very Happy
The porting is near on identical. The only difference is the output has one extra bolt in the flange. And unless you are running extreme conditions, I doubt it will blow off/warp the flange.
http://www.europeancarweb.com/tech/0105ec_supercha rger/
See picture 2, you turn it one way the air is pushed a certain direction, turn it the other way, the air goes the other way.
It is only when you get into twisted rotor, telfon tipped rotors (like the 6/71, 8/71 competition blowers) you might have problems. But I dont know enough about these to speculate Very Happy
*EDIT*
Anyway, the porting on the large blowers makes it impracticle to reverse the rotation, but this is getting away from the topic.
[Updated on: Thu, 27 May 2004 12:12]
VL_Commy
Re: reversing output of SC12/14 Thu, 27 May 2004 12:22 Go to previous messageGo to next message
oldcorollas:
For starters, I did do a search, and could not find my post in the results. It was only after posting this new thread, then searching through 5 pages of threads that i actually found the old thread, and then made a post in it, hence it being back on the first page.
Secondly, instead of being a dickhead to new members who dont actually know a whole heap about this stuff, you could actually help instead of posting stupid comments like this
"oldcorollas"
actually, no...
just hook it up normally, and run it backwards so it sucks air from the motor....
it is people like earlyrolla that actually help these forums by providing users with useful information that actually helps answer the question posed.
"oldcorollas"
swapping inlets and outlets? if they are the same in tems of porting, sure why not, give it a go and let us all know how it goes.... but why do you need us to confirm what you wan to do already? just give it a frickin go!!!! ffs...
Maybe people whos weekly income is larger than mine and can afford to do experiments on this sorta gear will have done them, hence why i ask. I know i dont intend to break pieces of machinery that i cant afford to break.
If you dont really know the answer to a question, as i sense you dont know the answer to this one, just let it go instead of posting useless comments and flaming other members.
V8_MA61
Re: reversing output of SC12/14 Thu, 27 May 2004 12:38 Go to previous messageGo to next message
dont waste your time dude, seriously it wont work well, if at all. buy a honda item if you're so keen to do it. or turbo it. Or buy a new motor/ car.
Re: reversing output of SC12/14 Thu, 27 May 2004 12:49 Go to previous message
edit...
sarcasm appears to be lost on some ppl.....
sigh......
http://www.rodshop.com.au/superchargers.htm
edit...
and big budgets??? the4 SC12/14 are cheap as shit.... break one, use it as a door stop Wink you can pick em up for $200.. thats about the cost of a decent tyre!!!! also costs more than a pretty decent ECU Razz
[Updated on: Thu, 27 May 2004 13:33]
Previous Topic:3S blocks - common oil pan gasket??
Next Topic:lowering Aw11
Current Time: Sat Oct 17 16:36:11 UTC 2026
Total time taken to generate the page: 0.0055549144744873 seconds
