Toymods » Tech & Conversions » mr2 engine mount
MR. 2
Parramatta
mr2 engine mount Wed, 26 May 2004 22:54 Go to next message
guys i have been having constant problems with my front engine mount the one bolting onto the gearbox, engine block and the cross member the one closest to the firewall, in the centre.
it keeps spitting out the bolts from both the box and the block. no matter what we do, lock tight, have rethreaded and and tried bigger bots it keeps spitting them out after time..
Im sure its due to the brass button clutch, has anyone else had these problems and how was it fixed!
by the way its a sw20 3sgte
[Updated on: Wed, 26 May 2004 22:55]
fatmr2
Re: mr2 engine mount Wed, 26 May 2004 23:49 Go to previous messageGo to next message
Its a torque mount. Have you had the mounts urethaned? Ive heard this helps with limiting the movement of the engine. I would assume that they keep coming out due to too much movement of the engine?
Im getting it done to my mr2.
Not sure if this will help but its just a thought.
Also, have you tried putting a split pin in the end of the bolt? Drill a hole in the end of the bolt and after you put the nut on put the split pin in. This will stop you from loosing the nut and bolt. could be a good safety thing anyway until you find exactly whats wrong.
bbaacchhyy
Re: mr2 engine mount Wed, 26 May 2004 23:53 Go to previous messageGo to next message
Drill the head of the bolts (they're mild steel so should be easy), get some 0.032" Stainless steel lockwire, a pair of lockwire pliers and lockwire them up a la aircraft style.
Sounds like that's the only way you'll solve your issue.
If you were in Adelaide, I'd even show you how to do it properly. 99% of people have no idea on how to do it so that it actually works Cool
Michael B
MR. 2
Parramatta
Re: mr2 engine mount Thu, 27 May 2004 03:54 Go to previous messageGo to next message
well i have no idea how to do that one bachy, if there is anyway you could get some images up it would be a huge help.
fatmr2 i cant put a split pin it it because they bolt directly into the box and block so there is no room for this. Other wise top idea
[Updated on: Thu, 27 May 2004 03:59]
bbaacchhyy
Re: mr2 engine mount Thu, 27 May 2004 23:00 Go to previous messageGo to next message
I can only show you haw to do it, as it was part of my trade (airframe fitter in the RAAF), and I don't have any books at home to be able to scan and host them.
One possible option is to go to the local library and see what they have under aircraft maintenance. If that doesn't yield something, I'll see what I can knock up by hand
Michael B
MR. 2
Parramatta
Re: mr2 engine mount Fri, 28 May 2004 04:40 Go to previous message
i will see what i can do cheers again!
Previous Topic:Silvertop Auto Redline
Next Topic:Making adjustable strut tops...
Current Time: Thu Oct 22 16:51:15 UTC 2026
Total time taken to generate the page: 0.073978900909424 seconds
