Toymods » Tech & Conversions » T series diff centres
Celica_RA40
T series diff centres Sat, 31 August 2002 13:06 Go to next message
I am looking at putting a new center and possibly a pinion gear into my celica diff i would like to know if it is possible to fit a LSD into the T series housing and if so what vehicles had them in stock???
i want something that will bolt in fairly straight forward like.
also how is the thrust clearence on toyota diffs adjusted? by shims or by a turning cam type thing?
Re: T series diff centres Sat, 31 August 2002 13:30 Go to previous messageGo to next message
T series LSD's are quite rare. You can find them in Jap-spec AE86's and some Jap-spec RA6x Celicas, but I probably don't need to tell you how common they are.
I believe Quaife make an LSD centre to suit RWD Celicas, but at $3k that may be a little out of your budget. Smile
Re: T series diff centres Sat, 31 August 2002 13:33 Go to previous messageGo to next message
You could get a TRD T series four pinion LSD for significantly less than 3K. Still, it will be around/over the 1K mark.
[Updated on: Sat, 31 August 2002 13:33]
Celica_RA40
Re: T series diff centres Sat, 31 August 2002 13:40 Go to previous message
Hmmmm it appears that i may be just buying a reco standard diff centre Smile
Previous Topic:Throttle Cable HELP
Next Topic:Moulded Carpet place - Vic/web
Current Time: Sat Oct 17 06:47:10 UTC 2026
Total time taken to generate the page: 0.0056419372558594 seconds
