Toymods » Tech & Conversions » 3t help!!! please!!!
steve-O
wollongong
3t help!!! please!!! Thu, 27 May 2004 07:23 Go to next message
i have dismantled my 3t today but then i had a sneaking suspision that i buggered up. without thinking i pulled a piston out from the bottom of the block then it got stuck somewhere near the crank mounts then i thought to myself that i screwed up.
can anyone tell if i stuffed up and if i can squeeze the rings back in the bore
any info would be appreciated
YelloRolla
On your mum!
Re: 3t help!!! please!!! Thu, 27 May 2004 08:41 Go to previous messageGo to next message
step 1) break rings
step 2) remove piston
step 3) buy new ring set
step 4) replace all ring sets
step 5) rest happily knowing that the easiest thing to make is still and always will be; a mistake.
steve-O
wollongong
Re: 3t help!!! please!!! Thu, 27 May 2004 09:34 Go to previous messageGo to next message
shit i was hoping it wasn't gonna come to this
do you know what new rings will cost? ball park figure
would i have to get anything done to the block?
sik sx
Sunshine Coast
Re: 3t help!!! please!!! Thu, 27 May 2004 11:47 Go to previous messageGo to next message
60 for rings .. 15-20 for ring compresser
and your done
good luck dude
steve-O
wollongong
Re: 3t help!!! please!!! Fri, 28 May 2004 08:01 Go to previous messageGo to next message
thanks for the help i got a quote from repco for a full set for $145 and i can get my hands on a ring compressor
will i have to get the block rebored or anything like that incase its worn strange??
Grega
melbourne.victoria.austra...
Re: 3t help!!! please!!! Fri, 28 May 2004 08:08 Go to previous messageGo to next message
depends - what are the bores like - can you still see the cross hatching in them - or are they scored (up and down) by knackered original rings and/or other defects....?
steve-O
wollongong
Re: 3t help!!! please!!! Fri, 28 May 2004 09:09 Go to previous messageGo to next message
the block that'll i'll probly be using blows a bit of smoke on start up and a bit in higher revs i haven't actually looked at the bore. but i would say that it is fairly worn
YelloRolla
On your mum!
Re: 3t help!!! please!!! Fri, 28 May 2004 12:22 Go to previous messageGo to next message
then you may need to borrow a hone and hone the bores before re-assembly.
7mgtema71
Re: 3t help!!! please!!! Sat, 29 May 2004 03:14 Go to previous messageGo to next message
Just in mind when honing your block that you really only get three rebuilds/hones before needing to up size your pistons or resleaving your block other wise you'll have excessive blow by and might loose compression, etc.
My 2c
steve-O
wollongong
Re: 3t help!!! please!!! Sat, 29 May 2004 05:56 Go to previous messageGo to next message
wot is a hone and how do you use it??? is it easy to do?
wot does it do exactly?
YelloRolla
On your mum!
Re: 3t help!!! please!!! Sat, 29 May 2004 06:38 Go to previous messageGo to next message
A hone is a set of stones that are spring loaded - they are connected to a shaft, you put this in the drill and run it up and down the bores to give a cross-hatched hone marks (you will see evidence of these marks in the bores).
The purpose of honing is to bed the rings.
steve-O
wollongong
Re: 3t help!!! please!!! Mon, 31 May 2004 09:00 Go to previous messageGo to next message
thanks guys that was a big help
i asked if we had one at work which we do so i at least now that i can get my hands on one
thetoyman75
Club President
Re: 3t help!!! please!!! Mon, 31 May 2004 12:39 Go to previous messageGo to next message
Steve,
Contact Phil at pittwater Brake and clutch. You will save some dollars on that ring set !
For his contact number check the sponsors page on the web site or keep an eye on the forums banners.
TA22
Re: 3t help!!! please!!! Mon, 31 May 2004 15:33 Go to previous message
u have a hone at ur work? i hope ur not a mechanic, and dont knw wat it is Smile
Previous Topic:Knife Edging and butchering a crankshaft
Next Topic:twin piston rear calipers @ 18mm
Current Time: Sun Nov 1 23:26:23 UTC 2026
Total time taken to generate the page: 0.0065150260925293 seconds
