Toymods » Tech & Conversions » does your TVIS do this?
pepsicola
does your TVIS do this? Thu, 27 May 2004 15:10 Go to next message
i've been driving my friend's ae86 with a 4age tvis engine.
I noticed, when i floored it. it will start rev very quick between 3k to 4.5k and then it slowed down a bit between 4.5-5.5 and continued to rev quick again.
only known problem of the engine is the O2 sensor is hanging in the engine bay, not fitted.
any thought?
Re: does your TVIS do this? Thu, 27 May 2004 15:16 Go to previous messageGo to next message
total guess, but is TVIS opening late? when can you hear it open?
pepsicola
Re: does your TVIS do this? Thu, 27 May 2004 15:19 Go to previous messageGo to next message
around 4.5 to 5. not 100% sure.
but how would it open late?
Re: does your TVIS do this? Thu, 27 May 2004 15:29 Go to previous messageGo to next message
LOL, when i get my A series engine book from ebay, i'll let ya know Wink
was just a thought. if it opens early, it'll lose power low, if it stays closed late, it will feel like less power up higher.. perhaps??
maybe it's actually opening early?
i dunno Wink just trying to help at 1.30am Very Happy
pepsicola
Re: does your TVIS do this? Thu, 27 May 2004 15:40 Go to previous messageGo to next message
that sounds about right.
any 1 else?
RWDboy
Re: does your TVIS do this? Fri, 28 May 2004 01:51 Go to previous messageGo to next message
I would fit the O2 sensor before I looked at the TVIS...you could check the vacuum hoses that are attached to the TVIS VSV.
If the T-VIS is opening late/early either way it will feel like there is a drop in power somewhere in the rev-range. If you can't tell whether it still has the same power up top, then you will need to get some professional to diagnose it.
cressTT
Re: does your TVIS do this? Fri, 28 May 2004 10:22 Go to previous messageGo to next message
i think it has nothing to do with the 02 sensor..i'm talking efi in general ..usually if you go wot..the ecu will ignore feedback form the o2 sensor ...
IRA11Y
Club Member
Re: does your TVIS do this? Fri, 28 May 2004 11:12 Go to previous messageGo to next message
look for vacume leaks around the TVIS vacume tank, it may be pulling up slowly, could even be a faulty diaphram
Re: does your TVIS do this? Sat, 29 May 2004 01:10 Go to previous messageGo to next message
TVIS.... such fun Razz
i would be agreeing with a few people here. What i might do is get a friend in the passenger seat whilst you drive, and watch the output from the ECU to the TVIS VCV as you build RPM.
If the ECU is switching the TVIS correctly, then you are searching for a vacuum (<-- see thats how you spell it IRA11Y:P) leak or something wrong with the mechanical movement of the TVIS "flaps"
pepsicola
Re: does your TVIS do this? Sat, 29 May 2004 14:25 Go to previous messageGo to next message
cool. thanks for the info.
can any one point me to this? with a pic?
what other place i should look at?
pepsicola
Re: does your TVIS do this? Sun, 30 May 2004 10:54 Go to previous messageGo to next message
Confused
ae86drift
sydney.au
Re: does your TVIS do this? Sun, 30 May 2004 11:43 Go to previous messageGo to next message
on a semi-related side note
any downfalls to not running an o2 sensor?
Re: does your TVIS do this? Sun, 30 May 2004 12:49 Go to previous messageGo to next message
mixture and fuel consumption, or leaning out, during cruise and light throttle.
ae86drift
sydney.au
Re: does your TVIS do this? Sun, 30 May 2004 13:25 Go to previous messageGo to next message
ah ok
thx
pepsicola
Re: does your TVIS do this? Sun, 30 May 2004 14:43 Go to previous message
yeh, i think the ecu is running as much as fuel as it can.
i got 70kms out of 10L, i think normally is about 100kms/10L.
Previous Topic:gear selector cable p/n needed
Next Topic:SC14 Supercharger
Current Time: Sun Nov 1 21:41:54 UTC 2026
Total time taken to generate the page: 0.018657922744751 seconds
