Toymods » Tech & Conversions » replacing sump gasket on 3sfe
OnAHigh
replacing sump gasket on 3sfe Thu, 27 May 2004 16:06 Go to next message
Any camry owner changed the sump gasket (3SFE)? Im planning of changing mine but it just looks to complex there are two many things in the way like the cross member, which also means i gotta unbolt the front engine mount. Is there a better way??
D.
sik sx
Sunshine Coast
Re: replacing sump gasket on 3sfe Fri, 28 May 2004 11:53 Go to previous messageGo to next message
dude drive your car up on some ramps, take the cross member out etc and put all nuts and bolts in a bucket..the engine will ballance on the 2 side ones it is fine, MAKE SURE U DRAIN OIL FIRST befor takeing the bolts out..u empty it by taking that huge nut from the bottom out and putting a bucket under it, replace the gasket and screw the sump back in and just reverse evertyhing u did..then put the oil back in and there ya go Smile
hope this helps
in my oppionion it is safe to take the front one off
good luck
OnAHigh
Re: replacing sump gasket on 3sfe Sat, 29 May 2004 16:46 Go to previous message
yeh bro, i got a fair idea of how to change it, it just looks like a hella of a hassle, but thanks for the info. im gonna try to get hold of some ramps cause the stands i got now arent to helpful as my jack wont go high enough
cheers.
Previous Topic:Changing Auto Kickdown position - Now Changed! *EDIT* - Pdf file on it
Next Topic:4age wiring questions.
Current Time: Tue Oct 27 08:08:17 UTC 2026
Total time taken to generate the page: 0.044910907745361 seconds
