Toymods » Tech & Conversions » S/C on GZE dont spool....Help!!!
MFX_AE86
Liverpool
S/C on GZE dont spool....Help!!! Thu, 27 May 2004 16:55 Go to next message
I just got my GZE into my sprinter & the charger isnt making boost.... anyone had this problem & can give me some tips on what 2 look at ?
Dave
M.W.P.
Rocky Mountains, Canada
Re: S/C on GZE dont spool....Help!!! Thu, 27 May 2004 17:07 Go to previous messageGo to next message
Starting with the most obvioius... is the SC clutch kicking in?
sideshow
Re: S/C on GZE dont spool....Help!!! Thu, 27 May 2004 22:04 Go to previous messageGo to next message
is the 4agze an older type
like one with yellow plugs on the ecu
or a newer one with grey plugs on the ecu
Henn
Rosanna, Melb
Re: S/C on GZE dont spool....Help!!! Fri, 28 May 2004 03:38 Go to previous messageGo to next message
Yeah, check SC clutch is coming on, and the relay powering it is working. Possibly super loose belt. You should be able to hear SC whine when engaged.
Or have you forgotten to connect up your intercooler pipes? Beyond this it could be electrical, and I'm not familiar with that.
Good luck
Hen
adamb131
Re: S/C on GZE dont spool....Help!!! Fri, 28 May 2004 04:14 Go to previous messageGo to next message
check the oil? check it has oil!
MFX_AE86
Liverpool
Re: S/C on GZE dont spool....Help!!! Fri, 28 May 2004 09:35 Go to previous messageGo to next message
thanks for the info guys..... keep it coming cause its still happenin.
M.W.P. how can you tell if its kickin in ???
sideshow : if you are the guy that runs sideshow then you ran the wiring for this engine out at PHD & the clips are yellow
I cant hear the charger working & the I/C pipes are fine... I checked engine has oil so that rules that out
dave
monkeymajik
Re: S/C on GZE dont spool....Help!!! Fri, 28 May 2004 09:52 Go to previous messageGo to next message
He means the supercharger oil, there should be a little butterfly nut ontop of the supercharger, thats the dipstick. It's could be a real bitch to get to Smile
M.W.P.
Re: S/C on GZE dont spool....Help!!! Fri, 28 May 2004 15:46 Go to previous messageGo to next message
MFX_AE86 wrote on Fri, 28 May 2004 19:05
Well you can see it if looking under the hood while it does click in, but you wont be able to do that while driving it obviously (unless your on a dyno).
Is the SC wired up properly?
MFX_AE86
Liverpool
Re: S/C on GZE dont spool....Help!!! Fri, 28 May 2004 15:57 Go to previous messageGo to next message
M.W.P. : all the pullies seem 2 be spining bar the one at the verry bottom on the left.... but the belt is spinning around it ??? hmmm...
sideshow performance did the wiring so i rekon its spot on...
dave
[Updated on: Fri, 28 May 2004 16:00]
adamb131
Re: S/C on GZE dont spool....Help!!! Sat, 29 May 2004 05:41 Go to previous messageGo to next message
Run the car and wathch the SC pulley.
Tthe centre of the pully should be still or spinning at a different speed to what the belts going round at. When the clutch magnetises the centre of the sc pulley will spin in time with the belt.
Watch it and rev the car with your hand. It should go clunk and start spinning same as belt when man pressure reaches about -6 psi. And check the SC has oil in it!
MFX_AE86
Liverpool
Re: S/C on GZE dont spool....Help!!! Mon, 31 May 2004 06:54 Go to previous messageGo to next message
Ok I have checked the oil in the charger & that is fine & also checked that the pulley whic does what its supposed 2 although there is no clunk noise when it engauges... I rechecked the I/C pipe & thats fine 2
Is there anything any one else can think of ?
Thanks for all the help so far guys
dave
Caution
sydney - liverpool
Re: S/C on GZE dont spool....Help!!! Mon, 31 May 2004 07:21 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=36476&start=0&rid=5496&S=f159d987bac 39d33464cf517d878bfd9
dave did you see this? Interested at all? sorry to hijack
boris
On probation
Brisbane, Queensland
Re: S/C on GZE dont spool....Help!!! Mon, 31 May 2004 07:24 Go to previous messageGo to next message
When driving the car does it feel like its making boost or is it definately lacking?
MFX_AE86
Liverpool
Re: S/C on GZE dont spool....Help!!! Mon, 31 May 2004 08:58 Go to previous messageGo to next message
Nope definatley no positive boost.... reads vaccume fine ( I got a boost gauge)
Caution : yeah i saw it.... no need 4 it though
dave
boris
On probation
Re: S/C on GZE dont spool....Help!!! Mon, 31 May 2004 09:22 Go to previous messageGo to next message
Ok thats cool, was just gonna say maybe the gauge is hooked up wrong. Razz
tripmcneily
Sydney, Peakhurst
tripmcneily
Re: S/C on GZE dont spool....Help!!! Mon, 31 May 2004 10:15 Go to previous message
sound like your mag. clutch isn't kicking in mate.
( to be honest I don't know all that much about the s/c setup... but I am an Aircraft sparky)
check your relay!
If thats fine then maybe your coil is open or shorted. if you can get a multimeter take a resistance reading (with the car NOT Running) - If you get A high or infinate reading = Open = McFUCKED!
- If you get a very very low reading less than say 5 ohms = open = Fucked!
More than likely (I'm 99.9% sure!) it will be a dodgy relay.
Previous Topic:JZX pedal's in an MX73 cressida?
Next Topic:Wiring question (12V from ACC)
Current Time: Sat Oct 31 14:43:36 UTC 2026
Total time taken to generate the page: 0.04977011680603 seconds
