Toymods » Tech & Conversions » Help with alternator to my TA22 w/4AGE
Grega
melbourne.victoria.austra...
Help with alternator to my TA22 w/4AGE Fri, 28 May 2004 00:10 Go to next message
OK
I've got myself a nice tiny alternator from a daihatsu - same as what the clubmans use basically.
It has an integrated regulator in it, my TA22 has an external reqgulator in it, what I want to know is what wires do I hook up to what;
http://www.vncommodore.com/images/celica/alt2.jpg
http://www.vncommodore.com/images/celica/alt1.jpg
i know the one marked B goes straight to the battery no issues there.
the 3 pin is what gets me. if you look at the second picture its marked with IG and L - IG i take it goes to IGnition, L i guess goes to the charge light which i don't use - where does the other one go and more importantly which pin is which.
Many thanks in advance for any help with this.
wadadlianu
Florida
Re: Help with alternator to my TA22 w/4AGE Fri, 28 May 2004 00:55 Go to previous messageGo to next message
You are correct with your designation for the terminals. The top bar is most likely the sense terminal that goes to the battery also. It lets the regulator know if to put out more voltage or to lower it
Grega
Re: Help with alternator to my TA22 w/4AGE Fri, 28 May 2004 02:54 Go to previous messageGo to next message
so thats what the S is for - sense
many thanks!!!!!!!
will go get wiring now...
Re: Help with alternator to my TA22 w/4AGE Fri, 28 May 2004 06:56 Go to previous messageGo to next message
Yep thats right - alternators with internal regulators really only connect to 3 points...
OUTPUT - to battery terminal
IG - Ignition
S - Voltage sense, to batt +
L - negative output for charge warning light.
It really is easy to hook this up to a car with external regulator - just utilise those standard 6-pin spade connectors.
Grega
Re: Help with alternator to my TA22 w/4AGE Fri, 28 May 2004 06:59 Go to previous message
thanks buddy christ.
Previous Topic:20 valve owners
Next Topic:Silvertop Auto Redline
Current Time: Mon Nov 23 05:42:55 UTC 2026
Total time taken to generate the page: 0.0040450096130371 seconds
