Toymods » Tech & Conversions » Pulley Size help pls.......
TK Ross Lancer
Pulley Size help pls....... Fri, 28 May 2004 04:37 Go to next message
ok i have a lancer coupe and am looking at using one of the Toyota supercharger's to do a converstion on my motor....i believe it is the 1G S/C off the 4AG-ZE, and i need to know a pulley size to run about 8PSI.....as i am not chnaging my internals yet.....
pls guys i really need some help here.....
thankx very much.
Ross
STR8 2.8
Re: Pulley Size help pls....... Fri, 28 May 2004 08:48 Go to previous messageGo to next message
a 1g supercharger...wouldnt that be from a 1ggze.
do you want a 4agze supercharger (sc12), or a 1ggze supercharger (sc14?) ?
nevo make some pulleys for the 4azge, 164 or 175mm if i remember correctly...
some ppl seem to be getting about 10-12psi from the smaller pulley..
[Updated on: Fri, 28 May 2004 08:55]
monkeymajik
Re: Pulley Size help pls....... Fri, 28 May 2004 08:54 Go to previous messageGo to next message
The sc12 from the 4agze does about 8psi with the stock pulleys. However I'm not sure what size pulley's your mitsu engine has...If you plan to go for bigger boost later and your custom fabricating stuff anyway, you might as well go for the sc14 from the 1ggze as it has more headroom for increases later on.
[Updated on: Fri, 28 May 2004 08:56]
TK Ross Lancer
Re: Pulley Size help pls....... Fri, 28 May 2004 08:58 Go to previous messageGo to next message
yeah i am still shoppn around for the unit....
how much would the sc12 or sc14 be???
monkeymajik
Re: Pulley Size help pls....... Fri, 28 May 2004 09:47 Go to previous messageGo to next message
JustJap have a 1ggze supercharger for $350
BlackSupra
Re: Pulley Size help pls....... Fri, 28 May 2004 10:19 Go to previous messageGo to next message
SC14 is good for what 12,000rpm?? (i think)
So figure out the ratio that is required by first determining how many revs you want to pull. The higher you rev the engine, the less boost it will make, as the ratio will be smaller.
So for example mitsu lists max power as 5500rpm. So take max blower speed 12000rpm = crank pulley speed of 5500rpm.
12/5.5 = 2.1
So for the blower to achieve 12000rpm at a MAXIMUM of 5500rpm (this is your new redline), the ratio of the blower pulley to that of the crank pulley is 2.1:1.
So measure up both the crank and the blower pulleys and figure out what ratio you currenlty have, then determine what you want.
TK Ross Lancer
Re: Pulley Size help pls....... Fri, 28 May 2004 10:58 Go to previous messageGo to next message
ahhh ok cool.....
now u guys or most of guys have 1st hand experience with these blowers.....which one of the 2 would u guys recommend i use for my car.....
it is the 1.8L lancer....all i really want for now is a low 14 second pass or so.....
reall appreciate it
[Updated on: Fri, 28 May 2004 10:58]
BlackSupra
Re: Pulley Size help pls....... Fri, 28 May 2004 15:21 Go to previous messageGo to next message
SC12 = 1.6L
SC14 = 2.0L
Re: Pulley Size help pls....... Sat, 29 May 2004 00:14 Go to previous messageGo to next message
you might require a little more than 8psi to achieve a low 14 pass. Most 4A-GZE equipped rollas do mid-low 14's, depending on the level of mods.
If you really want to go crazy - check out the SC20 Evil or Very Mad , i've almost had thoughts about using that bad boy on my celica.
Nevertheless, get yourself to a good performance workshop and do some talking before you make any concrete plans.
BlackSupra
Re: Pulley Size help pls....... Sat, 29 May 2004 02:34 Go to previous messageGo to next message
What the hell is that off?
Re: Pulley Size help pls....... Sat, 29 May 2004 07:03 Go to previous message
.... landcruiser Razz
Previous Topic:bov troubles
Next Topic:AE82 Twin Cam Handling article
Current Time: Sun Oct 25 04:38:03 UTC 2026
Total time taken to generate the page: 0.0049839019775391 seconds
