Toymods » Tech & Conversions » 4AGZE timing belt tensioner issues
4ageeza
Adelaide, drift capital
icon5.gif  4AGZE timing belt tensioner issues Fri, 28 May 2004 16:16 Go to next message
Gday, I am currently trying to get by head off of my GZE and I need to remove the timing belt and cams.
I'm down to the moving of the timing belt tensioner pulley in order to get off the timing belt and I realised
the nut fastening this is not a standard nut. It has a splined head and appears to require a special tool.
I have a 4AGE engine repair manual and it doesn't indicate the need of any special service tools
for its removal! Obviously the GZE is different. Does anyone know how to get this nut off?
I rang toyota and they have NFC about SSTs or anything about GZE disassembly. Could anyone help?
Thanks,
Joel
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4AGZE timing belt tensioner issues Fri, 28 May 2004 16:24 Go to previous messageGo to next message
G'day Joel. The bolt in question has a 12 point head, as opposed to the regular 6 point on most nuts & bolts. You need to get either a 12 point socket or ring spanner (10mm I believe) which are pretty common & should be easy to find.
Most sockets & almost all ring spanners are 12 point, as they work on both 6 & 12 point bolts/nuts.
feral4mr2
Bundaberg, Qld.
Re: 4AGZE timing belt tensioner issues Fri, 28 May 2004 22:53 Go to previous messageGo to next message
yes BigWorm's got it. 12point 10mm long socket or ring spanner. Smile
4ageeza
Re: 4AGZE timing belt tensioner issues Sat, 29 May 2004 00:48 Go to previous message
ahh thanks fellas Smile , I've only got a set of opened
end spanners, and my sockets aren't long enough!
I think it time for a tool investment.
Previous Topic:o2 sensor on 1jz
Next Topic:18RG alternator and starter motor
Current Time: Sat Oct 24 11:05:14 UTC 2026
Total time taken to generate the page: 0.0049769878387451 seconds
